» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
bass ackwards glow control
Swapping pump tops? Can it be done??
the differences between n/a pump and LDA pump's
choices what your advice
Smoke and noise
How to get 8000rpm's?
Boost Gauge
is a .63 A/R too large for the turbine side
speedo
Kick the Tires & Light the Fires
Loosing power in higher gears
So close... but not quite
help on converting wg can
top out at 150?
Changing the Serpintine Belt? (AAZ)
Best radiator upgrade? A1 rad upgrade?
throttle floating, at high rpm's... is it the pump
8V camshaft vs diesel camshaft (gears)
JLP diesel rebuilds
Been searching on all the boards and have yet to find it,
HELP!! is my exhaust manifold usable
motor mount bolt ?
mk1 cabby gas to diesel swap questions
blow by
The (official...) COMPOUND turbo thread!
Clutched pulley
Electronic VNT controller design - Updated!! Rev 0.1 :)
Not restarting once motor is warm
CV joints + power = ??
where can i get an injector socket 1.9AAZ
oil light,battery light, no tach
Boosting while cruising?
any magnesium on our engines?
Anyone used kennedy Adapter plate?
pump resealing agony
New guy with a 92' ECO have a few questions..
coolant temp sensors
AMC heads same as Kolbenschmidt?
WVO Observations
Who is running a Turbo Diesel or TDI Scirocco?
Bought two Garrett GT2056V turbo's Pictures added
Does my coolant Overflow tank need to refeed?
Is it possible to convert a ECO pump to a Turbo Pump?
Compressor wheel replacement and selection
Exhaust question on my aaz.
Finding 130 HP on a 1.6TD - What would YOU do?
nice night... um, are those sparks coming from US!?!?
pounding out precups?
Cleaning hard lines?
1.9 td possible tranny issue
