blow by
Topic: blow by (Read 5015 times)
April 12, 2009, 05:38:18 pm
ccoxva
Newbie
blow by
April 12, 2009, 05:38:18 pm »
How much blow by is normal. Mine is not dripping out of the tube or anything but seems like a little much for 200,000 miles?? Any input??
89' VW Jetta diesel
April 12, 2009, 06:53:29 pm
jettabrendan
geschwindigkeitsueberschreitung
blow by
April 12, 2009, 06:53:29 pm »
how much smoke comes out when you take off your oil cap?
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
April 12, 2009, 08:44:12 pm
ccoxva
Newbie
blow by
April 12, 2009, 08:44:12 pm »
Hard to see in the day but visable in the headlights. Its got the hole in the cap and a tube by a previous owner.
89' VW Jetta diesel
April 13, 2009, 10:02:04 am
blow by
April 13, 2009, 10:02:04 am »
if its hard to see, its probably not enough to worry over
April 13, 2009, 01:08:13 pm
blow by
April 13, 2009, 01:08:13 pm »
Your may already have one but..
When you take the cap off can you see the cam?
If yes get a new VC gasket and an oil baffle that goes under it.
Will help with the oil vapor.
April 14, 2009, 10:28:58 am
shegel
blow by
April 14, 2009, 10:28:58 am »
my 86 golf that had about the same mileage had soo much blowby that when i took the oil cap off it wouldnt sit on the valve cover. it would kinda float like a beach ball on a fan. and when i routed the hose from the valve cover to the intake manifold from the manifold to the air box the air box would fill up. and im sure it dripped oil into the engine.
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
April 14, 2009, 11:11:09 am
jettabrendan
blow by
April 14, 2009, 11:11:09 am »
I think some air blowing out is normal, but a lot of smoke isn't. Mine blows a bit of air out and no smoke.
April 14, 2009, 02:09:28 pm
ccoxva
Newbie
blow by
April 14, 2009, 02:09:28 pm »
There isnt any oil dripping out of the tube but it is a little wet inside. Just a little worried still learning the vw hand book :lol: Thanks guys!!!
89' VW Jetta diesel
April 14, 2009, 02:34:16 pm
jettabrendan
blow by
April 14, 2009, 02:34:16 pm »
If your really worried about it you could always do a compression test but it dosent sound bad
April 14, 2009, 04:02:08 pm
ccoxva
Newbie
blow by
April 14, 2009, 04:02:08 pm »
Might just see how long she'll go what I dont know wont hurt me. Right? :roll:
89' VW Jetta diesel
April 14, 2009, 06:13:27 pm
bigblockchev
blowby
April 14, 2009, 06:13:27 pm »
Check your oil mileage if it is not so good then a ring job might be in your future. If there is blowby your compression will be low leading to hard starting in cooler weather. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan MDJF 15Kw genset
Reply #11
April 15, 2009, 05:33:50 am
arb
blow by
Reply #11 on:
April 15, 2009, 05:33:50 am »
Quote from: "ccoxva"
Right. Being as you are in Virginia, you don't have many cold days, so if your rings are shot, you will not have too hard a time starting in the cold. (one trick if you have a really cold day, park on a really steep hill and roll start it - the fast spinning will more than make up for the cold and lower compression)
It will be a mater of diminishing returns - the more worn your rings, the more oil and fuel you will use. At first it will be cheaper to just drive it. As they get worst (years ??) you will get to the point its cheaper to do the ring job (if you have the skills / tools).
Reply #12
April 15, 2009, 03:51:14 pm
ccoxva
Newbie
blow by
Reply #12 on:
April 15, 2009, 03:51:14 pm »
Would I be better off to go ahead and find a turbo motor and build it and run this one till kabluie?
89' VW Jetta diesel
Reply #13
April 15, 2009, 10:08:07 pm
jettabrendan
blow by
Reply #13 on:
April 15, 2009, 10:08:07 pm »
i personally would lol
Reply #14
April 16, 2009, 10:17:58 am
harryold
Newbie
blow by
Reply #14 on:
April 16, 2009, 10:17:58 am »
I'm very new to the world of VW diesels. I just got mine about 1 month ago. It is a 91' jetta non-turbo diesel w/ 111,000 miles. I have been burning a little oil and noticed some smoke coming out when I take off my oil cap. What exactly does this mean?
blow by
