Author Topic: blow by  (Read 5066 times)
April 12, 2009, 05:38:18 pm
ccoxva
  • 15
blow by
« on: April 12, 2009, 05:38:18 pm »
How much blow by is normal. Mine is not dripping out of the tube or anything but seems like a little much for 200,000 miles?? Any input??
89' VW Jetta diesel
Reply #1April 12, 2009, 06:53:29 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
blow by
« Reply #1 on: April 12, 2009, 06:53:29 pm »
how much smoke comes out when you take off your oil cap?
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #2April 12, 2009, 08:44:12 pm
ccoxva
  • 15
blow by
« Reply #2 on: April 12, 2009, 08:44:12 pm »
Hard to see in the day but visable in the headlights. Its got the hole in the cap and a tube by a previous owner.
89' VW Jetta diesel
Reply #3April 13, 2009, 10:02:04 am
blow by
« Reply #3 on: April 13, 2009, 10:02:04 am »
if its hard to see, its probably not enough to worry over :)
Reply #4April 13, 2009, 01:08:13 pm
blow by
« Reply #4 on: April 13, 2009, 01:08:13 pm »
Your may already have one but..
When you take the cap off can you see the cam?
If yes get a new VC gasket and an oil baffle that goes under it.
Will help with the oil vapor.
Reply #5April 14, 2009, 10:28:58 am
shegel
  • 312
blow by
« Reply #5 on: April 14, 2009, 10:28:58 am »
my 86 golf that had about the same mileage had soo much blowby that when i took the oil cap off it wouldnt sit on the valve cover. it would kinda float like a beach ball on a fan. and when i routed the hose from the valve cover to the intake manifold from the manifold to the air box the air box would fill up. and im sure it dripped oil into the engine.
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #6April 14, 2009, 11:11:09 am
jettabrendan
  • 198
blow by
« Reply #6 on: April 14, 2009, 11:11:09 am »
I think some air blowing out is normal, but a lot of smoke isn't. Mine blows a bit of air out and no smoke.
Reply #7April 14, 2009, 02:09:28 pm
ccoxva
  • 15
blow by
« Reply #7 on: April 14, 2009, 02:09:28 pm »
There isnt any oil dripping out of the tube but it is a little wet inside. Just a little worried still learning the vw hand book :lol:  Thanks guys!!!
89' VW Jetta diesel
Reply #8April 14, 2009, 02:34:16 pm
jettabrendan
  • 198
blow by
« Reply #8 on: April 14, 2009, 02:34:16 pm »
If your really worried about it you could always do a compression test but it dosent sound bad
Reply #9April 14, 2009, 04:02:08 pm
ccoxva
  • 15
blow by
« Reply #9 on: April 14, 2009, 04:02:08 pm »
Might just see how long she'll go what I dont know wont hurt me.    Right? :roll:
89' VW Jetta diesel
Reply #10April 14, 2009, 06:13:27 pm
bigblockchev
  • 271
blowby
« Reply #10 on: April 14, 2009, 06:13:27 pm »
Check your oil mileage if it is not so good then a ring job might be in your future. If there is blowby your compression will be low leading to hard starting in cooler weather. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #11April 15, 2009, 05:33:50 am
arb
blow by
« Reply #11 on: April 15, 2009, 05:33:50 am »
Quote from: "ccoxva"
Right. Being as you are in Virginia, you don't have many cold days, so if your rings are shot, you will not have too hard a time starting in the cold. (one trick if you have a really cold day, park on a really steep hill and roll start it - the fast spinning will more than make up for the cold and lower compression)
It will be a mater of diminishing returns - the more worn your rings, the more oil and fuel you will use. At first it will be cheaper to just drive it. As they get worst (years ??) you will get to the point its cheaper to do the ring job (if you have the skills / tools).
Reply #12April 15, 2009, 03:51:14 pm
ccoxva
  • 15
blow by
« Reply #12 on: April 15, 2009, 03:51:14 pm »
Would I be better off to go ahead and find a turbo motor and build it and run this one till kabluie?
89' VW Jetta diesel
Reply #13April 15, 2009, 10:08:07 pm
jettabrendan
  • 198
blow by
« Reply #13 on: April 15, 2009, 10:08:07 pm »
i personally would lol
Reply #14April 16, 2009, 10:17:58 am
harryold
  • 3
blow by
« Reply #14 on: April 16, 2009, 10:17:58 am »
I'm very new to the world of VW diesels.  I just got mine about 1 month ago.  It is a 91' jetta non-turbo diesel w/ 111,000 miles.  I have been burning a little oil and noticed some smoke coming out when I take off my oil cap.  What exactly does this mean?
