Author Topic: motor mount bolt ?  (Read 2239 times)
April 17, 2009, 09:20:24 am
allsierra123
motor mount bolt ?
« on: April 17, 2009, 09:20:24 am »
Anyone know what size the bolts that connect the motor mounts to the engine carrier bars are in a diesel vanagon? I can tell they are rather large but cant seem to locate the size anywhere.
Reply #1April 17, 2009, 03:46:31 pm
  • 1739
motor mount bolt ?
« Reply #1 on: April 17, 2009, 03:46:31 pm »
Find Vag-Cat on line , look up a factory engine mount setup and the bolts should be listed.
Reply #2April 18, 2009, 12:14:36 am
allsierra123
motor mount bolt ?
« Reply #2 on: April 18, 2009, 12:14:36 am »
Ok did that this is what it gives for the size.
M14X1,5X135
Is that two sizes or is it all ones size. Forgive my ignorance on this.
Reply #3April 18, 2009, 04:46:13 am
clbanman
  • 705
    Cambridge, Ontario
motor mount bolt ?
« Reply #3 on: April 18, 2009, 04:46:13 am »
14 mm nominal diameter, 1.5 thread pitch, 135 mm long.
Calvin
91 VW Golf 1.6NA 5spd
Reply #4April 18, 2009, 08:35:19 am
allsierra123
motor mount bolt ?
« Reply #4 on: April 18, 2009, 08:35:19 am »
perfect thank you.
