View full version: IDI Engine
  1. Gauges...which ones?
  2. Turn camshaft by hand?
  3. TDI fuel fittings on a IDI pump
  4. Weber intake manifold on a diesel???
  5. M12 or T-55 for head bolts?
  6. Do I need AAZ injector lines.....?
  7. Piston Damage
  8. Would You Run This Cylinder head?
  9. 150hp+ aaz build
  10. Volvo D24 VNT Project.
  11. I'm building a glow plug controller, looking for your input.
  12. Interest in co-developing a stand-alone ECU for 16V CR engines?
  13. What to do with some of my sad old parts: cyl head and inj pumps
  14. GT1548 turbo
  15. Gauge for stock oil temp sender (and psi sender?)
  16. Head Bolts or Studs (1588)
  17. 1.6 td alternator wiring swap
  18. idle adjustment after fuel screw adjustment
  19. Theft. Switch. Silinoid ip pump
  20. Check bolts while my oil pan is off?
  21. NOS AAZ cam caps (?)
  22. Coolant overflow leaking fluid out the cap
  23. Pumps. Difference. 1.6 eco 81 na
  24. 1.6 pump on a 1.9 VW Westy with a Holset
  25. Smaller cooler for 1.6TD
  26. 1.6 Td Idle rev hang SOLVED
  27. Testing for boost leaks - Holset
  28. IP Throttle Advance: Mechanical vs. Vacuum Actuated
  29. 1.6td - first head gasket job questions
  30. 11mm 1.6, are they that bad?
  31. RIP The Black Lady
  32. 1.5 Diesel cutting out under acceleration
  33. vw 2.4 5 cilinder diesel
  34. Thoughts on oil in a marine engine
  35. Tighten alternator belt
  36. 1.6 TD Head Injector Seat Issue
  37. 1.6TD low on power
  38. 1.6TD bucking \ surging off of idle
  39. Rebuilding: 1.6TD JX Turbo Diesel engine
  40. Gearbox to match rebuilt 1.6TD JX engine
  41. Need to lower idle
  42. 1.6L IDI performance
  43. OEM vw oil cooler warmer delete........will the turbo survive?
  44. Oil light at high RPM's
  45. New pump.... Lots of smoke
  46. AAZ mods question
  47. Cranked motor out of timing..
  48. new exhaust valves?
  49. MF engine. Finding crank top dead center TDC WITHOUT timing belt or flywheel
  50. White smoke and rough idle still occurs after timing - what next?
