Author Topic: New pump.... Lots of smoke  (Read 2984 times)
February 07, 2017, 06:33:59 pm
caykroyd
  • 15
« on: February 07, 2017, 06:33:59 pm »
I read a bunch about smoke and am confused about a couple things.
I have white/grey smoke at cold and idle which clears up once engine warms up.  I think I've read this is ok, correct?
Then of acceleration (even moderate) I get a bunch of black smoke.  So I know I can turn down the fuel screw, but I like the power ;-).  Are there other options to reduce the smoke?
Thirdly, this seems weird to me.... At high cruising speed, I don't have smoke, but when I let off the pedal to slow down I get a huge plume of smoke.  This seems counterintuitive to me.  Does this make sense?  Is this a symptom of something other that just running too rich?  Why would this happen?
BTW, it is a Giles 1.6NA pump.
Sent from my iPad using Tapatalk
Reply #1February 07, 2017, 08:09:42 pm
RunninWild
  • 609
Re: New pump.... Lots of smoke
« Reply #1 on: February 07, 2017, 08:09:42 pm »
Maybe try contacting giles... The guy who built you the pump..
 And if the smoke is thick and black you better have a egt gauge installed or you are likely to melt the pistons.
Reply #2September 24, 2017, 06:49:04 pm
spider_df
  • 1
« Reply #2 on: September 24, 2017, 06:49:04 pm »
do you have guiles email? iīm from Brazil, here we donīt have a person to tune the pump.
Reply #3September 24, 2017, 07:43:45 pm
« Reply #3 on: September 24, 2017, 07:43:45 pm »
Performance Diesel Injection in Ontario, Canada is his business. That's the easiest way to contact him.
Sent from my LG-H873 using Tapatalk
