» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
mods on 1y
Machining in oil squiters
AAZ, RPMs out of control, doesn't seem like runaway though
Finally! no more leaks from the head coolant flange
AAZ Serpentine Belt Question
IP id?
(Not) Starting mystery.....
1.6 diesel belt tension and torque specs
1.6TD cam shaft on AAZ
Good sources and part numbers for Hydro Lifters.
What should my egt's be at?
Where does this green wire go?
Why would you put a 1.5 head on a 1.6 block?
Qunatum turbo in an 82 diesel pickup?
Max Boost Questions??
oil pressure buzzer location
1.6 n/a "mini-build"
New Head Install / With Extrude A Hone Polishing ( Plasma ) 1.9 AAZ
What grade gear oil
Well, my waterpump finally went
D'oh!!!
Problems SOLVED with Techtonics Tuning -- Josh came through!
My B3
'hunting' idle
intake manifold bolt legnth
Max Fuel Screw question...
few things that bug me after engine swap
1984 Rabbit IDI Swap
When replacing engine mounts on a 93 AAZ
Injector to head sealing
1.5D will push start but not with starter.
A quick water hose query
how do i get these pistons out?
Cold start cable part # A1 Rabbit
metal hg question
91 N/A pump questions
safe egt
best turbo for aaz
85 td jetta rebuild w/ n/a td swap
Cracked Head Removing Injector Pics
AAZ in a diesel vanagon
Piston wrist pin circlips
dial indicator-why
Straight through exhaust
A different 1.6TD Conversion
Potential new down pipe manufacturer
k14 wastegate question
Turbo return line
V.W. Engine Oil Pan Guard : Fitment 1.6 / 1.8 & 1.9
new member with stupid questions
