» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Camshaft 180 degree off
VNT15 on 1.6 Diesel
1.6 Crank Sprocket Bolt and Washer
Slow vac build up along with low oil pressure when hot
Rod and Main bearings
Timing Question
My firtst 1.9 IDI
10mm pump with 11mm head hybrid questions
1.6TD head on a AAZ?
Found: one Bosch VE six cylinder pump
Radiator fan switch Temps.
problems at starting,power related?
distributor head o-ring, remove IP or in car?
1990 jetta 1.6 manual clutch went poof
Best "Base" pump for modifying.
valve shims getting thinner
Picked up a new pump...
AAZ oil pan gasket.....RTV or dry?
Is there a way to get rid of the vacuum pump?
Query for Dial Indicator Timing but samedifferent
Mk3 TD AAZ Timing Belt Tensioner, which style tenssioner to use?
VW 1.6TD JX Engine fuel issues 1984 Vanagon + Sleeveing
5 liter oil capacity.......how much circulates?
Aaz head option
Timing belt noise?
Aaz build
What pump for old style 10mm head ?
Oil pressure lost
AAZ oil pressure lost
1.6TD Piston Ring differences
1Y conrod bearing set number
Is 220 degrees too hot?
Using oil with 3000 miles on rebuild
Water pump pulley
Ko3 boost / vs rpm
So I just tuned the aaz pump
Aaz safe boost
1.6TD and rotating the boost pin
1.6td pump on AAZ issues
LDA leak on a new Giles pump (observations after resealing)
Leaky 1.6TD IP and less power but only after it warms up -
good source for valve cover studs for 1Y AAZ engine
1.9 ALH good deal or not?
1.9 AAZ vaccum diagram?
Valve interference?
1.6 TD went bye bye🙄Need Help
Audi or Fox oil pan on an AAZ?
Hate to be "that guy"
New Member with some 1Y issues
Coolant leak at pump return tee
