Author Topic: Loosing power in higher gears  (Read 4507 times)
April 18, 2009, 04:59:01 pm
catlin_cava
  • 1954
« on: April 18, 2009, 04:59:01 pm »
I find in 1st and 2nd from 2500rpm to 5000rpm the car flies up it, in 3rd 4th 5th then car hesitates going from 2500 up. and when i took off the line going from the turbo to the IP to look at setting up a boost gauge there was oil in that line, is that normal? :shock:
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1April 18, 2009, 05:09:36 pm
« Reply #1 on: April 18, 2009, 05:09:36 pm »
Depends on how much oil is in there.
If you take the top of the LDA off you'll probably find that it's full of oil.
You should take the intake boot off and check the turbo for play.
Reply #2April 18, 2009, 05:15:28 pm
catlin_cava
  • 1954
« Reply #2 on: April 18, 2009, 05:15:28 pm »
will do that tomorrow, i find when I drive the car hard...4500rpm down the highway for 5 minutes it smells strong like burnt oil/ carbon burning...
Catlin
Reply #3April 19, 2009, 04:18:11 am
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: April 19, 2009, 04:18:11 am »
Quote from: "catlin_cava"
I think that's normal. I get that too a bit. it smells a bit like things are getting hot and i think that's all it really is ... stuff getting hot. cooking what ever organic material is on there.
Reply #4April 19, 2009, 04:37:59 am
catlin_cava
  • 1954
« Reply #4 on: April 19, 2009, 04:37:59 am »
ok thats good, i though i was on my way to frying another motor...
Catlin
Reply #5April 19, 2009, 05:43:11 am
catlin_cava
  • 1954
« Reply #5 on: April 19, 2009, 05:43:11 am »
Ok is there supose to be play on the intake part of the turbo? If so how much? if not then I guess its f*cked...there is about 1/8"inch of play up and down on it...and tere is a bit of oil inside there. :shock:
Catlin
Reply #6April 19, 2009, 05:50:47 am
ccoxva
  • 15
« Reply #6 on: April 19, 2009, 05:50:47 am »
I  would say you wouldnt want quit that much. I am more into the bigger truck stuff but 1/16 up and down but the in and out is what I worry about the most.
89' VW Jetta diesel
Reply #7April 19, 2009, 06:53:29 am
« Reply #7 on: April 19, 2009, 06:53:29 am »
You should start looking for a replacement turbo. It's getting there. I wouldn't say you've reached a critical state yet though. If you plan to rebuild it, do it asap before it hits the housing, then it's no good.
Does your car have the regular style of wastegate control or VWs crazy idea of limiting it with a vacuum switch? You can tell simply by looking for any vacuum lines coming off the wastegate leading to the airbox area.
Reply #8April 19, 2009, 07:51:01 am
catlin_cava
  • 1954
« Reply #8 on: April 19, 2009, 07:51:01 am »
To be honest i don't know... heres some pictures lol :lol:
[/img]
Catlin
Reply #9April 19, 2009, 09:20:12 am
« Reply #9 on: April 19, 2009, 09:20:12 am »
just rebuild it.. or buy a good used one.. t3's are easy to come across.. that is just a normal t3 right?
Reply #10April 19, 2009, 09:36:04 am
« Reply #10 on: April 19, 2009, 09:36:04 am »
It's probably a K03 actually (AAZ engine), and it does in fact have the dreaded vacuum-actuated wastegate defeater designed to limit turbo action for emission reasons.
The FAQ ("make your 1.9 faster" thread) covers off what to do.... although I don't think it mentions pulling the vaccum hose off the back of the wastegate once you've disabled the throttle switches etc.
I believe venting to atmosphere makes the wastegate work properly, as opposed to vacuum... Tyler: do you know for sure?
Reply #11April 19, 2009, 09:38:28 am
« Reply #11 on: April 19, 2009, 09:38:28 am »
You have VWs crazy boost limiting idea.
Cut the hose at the arrow. Plug up the A end of the hose and leave the B end open to atmosphere.
This will give you boost when the engine needs it, not when VW thinks you should have it.
This will accelerate the wear on your turbo though.
DISCLAIMER
Get someone to verify what I just said. I hate turbos and could be wrong
Reply #12April 19, 2009, 09:40:57 am
« Reply #12 on: April 19, 2009, 09:40:57 am »
Quote from: "Vincent Waldon"
I'll second it likely being a K03.
Vince: I'm not sure. I had one on the workbench today and using compressed air it seemed to function as it should with the mod done in my picture above.
Reply #13April 19, 2009, 09:56:07 am
« Reply #13 on: April 19, 2009, 09:56:07 am »
you also have an exhaust leak.. notice that hole right below your flex coupling?
Reply #14April 19, 2009, 10:00:33 am
« Reply #14 on: April 19, 2009, 10:00:33 am »
Quote from: "Rabbit on Roids"
Sharp eyes. :wink:
Is it just me, or is CSI:Engine Compartment Pictures one of the funnest games ever??!!!!
