Author Topic: power steering delete  (Read 3640 times)
July 24, 2008, 02:23:45 pm
trent77
  • 217
« on: July 24, 2008, 02:23:45 pm »
Can I just remove the power steering pump and attach the hoses together, fill it up and use my car? The ps pump I got has the wrong flange on it and I don't have a gear puller, and don't want to buy one. Please tell me that this will work, and my fuel mileage will increase and there will be peace in the middle east.... Thanks everyone
Trent
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1July 24, 2008, 02:56:47 pm
gigaz2
  • 626
« Reply #1 on: July 24, 2008, 02:56:47 pm »
why not just put a non-power steering rack? less weight and all ;)
Reply #2July 24, 2008, 02:58:24 pm
trent77
  • 217
« Reply #2 on: July 24, 2008, 02:58:24 pm »
no time right now. I probably will in the future, I just want to know if I can drive it awhile like this. And aren't there a few things that I need to switch to manual? Thanks
77 westfalia
06 GMC Duramax
Reply #3July 24, 2008, 03:34:20 pm
Turbinepowered
  • 1206
« Reply #3 on: July 24, 2008, 03:34:20 pm »
It would be hard as crap to turn. The racks are geared and advantaged differently, turning a PS rack without the power assistance is a PITA.
Reply #4July 24, 2008, 04:35:20 pm
gigaz2
  • 626
« Reply #4 on: July 24, 2008, 04:35:20 pm »
and dangerous, as it can lock without warning if it fails ( I tried it on my Clio, similar system, real scary)
Reply #5July 24, 2008, 05:18:39 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: July 24, 2008, 05:18:39 pm »
You'll be fine as long as there is fluid in the rack.
Reply #6July 24, 2008, 07:25:19 pm
Choppercat
  • 42
« Reply #6 on: July 24, 2008, 07:25:19 pm »
My PS pump went south one day; it was squirting fluid strait toward the hot section of the turbo through the vent in the ps tank cap. What a smoke show! :shock:  All I could think of to get me going again was to just cut the PS belt off. I ran it without the pump spinning for a few months before replacing the pump. No harm could have been done and it was not even hard to steer; it made no difference on the road but it was a little heavy when not or barely moving.
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
Reply #7July 24, 2008, 07:32:01 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: July 24, 2008, 07:32:01 pm »
power steering without power=better be using your man-arms
manual steering=man-arms not necessarily required.
Reply #8July 24, 2008, 08:51:49 pm
trent77
  • 217
« Reply #8 on: July 24, 2008, 08:51:49 pm »
I took it for a drive and it wasn't to bad at all. Steering while sitting is a bit tough, but not unbearable, when moving it is not bad at all. What does it take to changeover to manual steering? Thanks for the input.
77 westfalia
06 GMC Duramax
Reply #9July 25, 2008, 07:09:30 am
trent77
  • 217
« Reply #9 on: July 25, 2008, 07:09:30 am »
Anybody know what is needed for the changeover? Thanks
77 westfalia
06 GMC Duramax
Reply #10July 25, 2008, 07:43:41 am
BellCityDubber
  • 251
« Reply #10 on: July 25, 2008, 07:43:41 am »
Quote from: "trent77"
a new rack, depending on the splines of the rack, a new knuckle from column to rack, the new rack may come with new tie rods, I don't know about tie rod ends but might as well get some...
you'll have to drop your subframe a tad to squeeze in/out the rack....
remove the lines, tank, pump, etc....
it's a fair sized job, but not impossible...
Reply #11July 25, 2008, 07:53:54 am
gigaz2
  • 626
« Reply #11 on: July 25, 2008, 07:53:54 am »
I replaced my non-ps rack from underneath, tedious, but doable on a car lift or pit.
Reply #12July 25, 2008, 10:29:23 am
bvolks73
  • 183
« Reply #12 on: July 25, 2008, 10:29:23 am »
Quote from: "gigaz2"
I've done 3 on my car so far with the car on jackstands, outside on the bare ground without a lot of trouble. Might be different with power steering though. Seems like PS makes everything more of a pain.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #13July 25, 2008, 11:14:26 am
gigaz2
  • 626
« Reply #13 on: July 25, 2008, 11:14:26 am »
jackstands? respect! ;)
done that on my brothers mk3 (tdi with PS), took me forever, a lot easier on the lift.
Reply #14July 26, 2008, 12:40:50 pm
madmedix
  • 204
« Reply #14 on: July 26, 2008, 12:40:50 pm »
I'm about to do this to my Jetta. Gotta get together the rack and knuckle first...
'90 TD Jetta
