Author Topic: Downpipe Question and Issues  (Read 2742 times)
October 02, 2009, 03:53:34 pm
jack's lack
  • 275
« on: October 02, 2009, 03:53:34 pm »
So my $350 custom stainless steel downpipe showed up this week, two months after I ordered it, and the flange doesn't mate up with my turbo.
The gasket looks familiar though, and I was wondering what turbo is it for? My receipt says MK1 1.9L IDI AAZ, K14 turbo, which it the info I gave them, so the screw up isn't there.
It looks like I might be able to drill 2 more holes for the lower bolts to make it to fit, but I don't think I should have to do that. I would send it back, but if it means waiting another two months for the right one I am not going to handle that well. Another strange bit is that there was a shortshift kit for a 020, looks just like the one on my MK1, in the box that I did not order and is not on my receipt, which makes me think my box may have been mis-labeled and this is not my exhaust at all. I have polished the tailpipe already, so I hope that is not the case.
if you were me, what would you do?
I would like to know as much as possible before I call the vendor
The gasket it came with, does not match mine
The new dp next to the oem one. The difference is easy to see
The hot side of my turbo
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #1October 02, 2009, 05:13:38 pm
catlin_cava
  • 1954
Re: Downpipe Question and Issues
« Reply #1 on: October 02, 2009, 05:13:38 pm »
Your new down Pipe looks like it would fit a K03 turbo....
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2October 02, 2009, 06:02:11 pm
« Reply #2 on: October 02, 2009, 06:02:11 pm »
Sounds like a mixup in which case it's their fault and you should be able to just send it back and get the right one, hopefully faster this time. ::)
Reply #3October 02, 2009, 08:45:03 pm
rabbid79
  • 684
« Reply #3 on: October 02, 2009, 08:45:03 pm »
If you purchased that downpipe from Techtonics, the short-shift kit is automatically included with the downpipe.  They say it's needed so the pipe will clear the shift linkage.  It probably wasn't a mix-up.
'15 WRX
Reply #4October 02, 2009, 09:09:39 pm
jack's lack
  • 275
« Reply #4 on: October 02, 2009, 09:09:39 pm »
well that answers the short shift question. I wasn't trying to name names, but still the dp still does not fit the turbo. I'll call them Monday I guess. seems like just the wrong turbo flange. Hopefully they can cut the old one off and weld the new one on.
My Build Thread
Reply #5October 02, 2009, 09:16:44 pm
rabbid79
  • 684
« Reply #5 on: October 02, 2009, 09:16:44 pm »
I'm not sure it's worth the $100 in shipping and time to send it back to them.  I'd either drill a couple of new holes and perhaps cut the excess off the flange, or ask them to send you a square flange and have it welded locally.  Maybe just do like you said earlier and keep the flange like it is and drill 2 new holes.  Then it would be "universal" for a couple different types of turbos in case you ever sell it in the future.
'15 WRX
Reply #6October 03, 2009, 08:59:09 am
GEE-BEE
  • 1604
« Reply #6 on: October 03, 2009, 08:59:09 am »
I sent them my Turbo assy  because of this, I got a k14 type and needed a K03
Gee-Bee
Josh  ( Techtonic's )will help you , the have both patterns now...
K03 & K14 FLANGE TYPE....
« Last Edit: October 03, 2009, 04:29:57 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
