Author Topic: Just a power question  (Read 2828 times)
September 30, 2009, 10:22:54 am
  • 3468
    • McScrubbins Body Wash
« on: September 30, 2009, 10:22:54 am »
Is this normal voltage to be reading at the battery?
battery light is OFF
running lights (no head lights) and nothing else - 11.89v
lights, stereo - 11.73v
lights, stereo, defrost, heater blower - 11.57v
car off ignition off - 12.12v
That was yesterday after a 15 minute drive
Now after a 15 minute drive my battery light is ON/flickering and i put my multimeter to the battery with stereo & lights on and it read 14.33v...
Reply #1September 30, 2009, 12:19:21 pm
Re: Just a power question
« Reply #1 on: September 30, 2009, 12:19:21 pm »
You have a bad voltage regulator.. are they built in to the alt's? I think they are. New Alternator I think Ed... :(
Reply #2September 30, 2009, 06:04:00 pm
« Reply #2 on: September 30, 2009, 06:04:00 pm »
seems normal to me. After a drive leave it sit before your test about an hour or turn your headlights on for a couple seconds to get the static charge off of it, then test and I bet it will be in range...or you'll know if she is junk.
Reply #3September 30, 2009, 06:05:11 pm
« Reply #3 on: September 30, 2009, 06:05:11 pm »
ohh wait.. are these values running or not running?
« Last Edit: September 30, 2009, 07:51:27 pm by burn_your_money »
Reply #4October 01, 2009, 12:51:57 am
  • 3468
« Reply #4 on: October 01, 2009, 12:51:57 am »
That is the only non-running value.
If they all seem normal why is my battery light on/flickering. It's never solid. It's always a flicker, sometimes MUCH brighter than other times.
Sometimes when i open the door my light in the roof will pulsate.
You can replace the V-regulator i thought Jer?
Reply #5October 01, 2009, 01:09:38 am
Turbinepowered
  • 1206
« Reply #5 on: October 01, 2009, 01:09:38 am »
Sounds like the regulator is dying, on its way out rather than already flatlined.
As I recall, the regulator and brushes are a single replaceable unit, and fairly easy to acquire.
Reply #6October 01, 2009, 01:22:19 am
  • 3468
« Reply #6 on: October 01, 2009, 01:22:19 am »
SHWeeet i'll hit up the local parts stores.
Reply #7October 01, 2009, 10:09:10 am
« Reply #7 on: October 01, 2009, 10:09:10 am »
Upgrade your grounds while you are at it.  The Voltage Regulator is cheap and should be in-stock just about anywhere.
Run a good ground from one of the case bolts on the alternator, and another one from one of the bolts on the valve cover.
Reply #8October 01, 2009, 01:11:24 pm
  • 3468
« Reply #8 on: October 01, 2009, 01:11:24 pm »
ah valve cover.. ok. wouldnt have thought there but that is easy enough to do.
