Author Topic: Clicking  (Read 2948 times)
July 01, 2005, 05:45:51 pm
TD_vento
  • 39
Clicking
« on: July 01, 2005, 05:45:51 pm »
Need to get an opinion on this clicking noise i get, basically when the car is iddling and I rev it on neutral there is no noise, when im driving and say im doing about 2000rpm and i floor it it slowly start to climb, and a clicking noise can be heard.  I been thinking is the injectors?  Why dont i hear this on iddle but only when the car is moving, i suspected it was a leak in the exhaust, but it all looked ok when i checked.  Do you hear this in your diesel?  Any comments?
thanks
Reply #1July 04, 2005, 06:23:03 pm
TD_vento
  • 39
Clicking
« Reply #1 on: July 04, 2005, 06:23:03 pm »
it might be the tappets/lifters, but im puzzled to why the noise appears when the car is on full throttle and accelerating but cant be heard when reving on iddle :?
Reply #2July 04, 2005, 06:45:32 pm
QuickTD
  • 1156
Clicking
« Reply #2 on: July 04, 2005, 06:45:32 pm »
It does sound like an exhaust leak. A leak right at one of the exhaust port gaskets will get louder under load. Is it a TD or an NA engine?
Reply #3July 05, 2005, 02:30:29 am
TD_vento
  • 39
Clicking
« Reply #3 on: July 05, 2005, 02:30:29 am »
Its a TD, that is what i initially thought leak in the exhaust system as it only appears under load, im not looking forwards to removing the manifold :x
Reply #4July 05, 2005, 01:49:51 pm
Baxter
Clicking
« Reply #4 on: July 05, 2005, 01:49:51 pm »
Obviously diagnosing sounds over t'internet is kinda tricky, could it be a "wrapping" from a big end or main bearing?
Reply #5July 12, 2005, 09:50:50 pm
Clicking
« Reply #5 on: July 12, 2005, 09:50:50 pm »
clicking sounds like the old audi 5000's...  They always seemed to click at idle.   Turns out it was some exhaust manifold leak problem (bad studs I think...)  but the clicking went away at around 3k rpm.  (less vibrating)
