Author Topic: My new Golf GTD - jingling noise  (Read 3669 times)
March 10, 2009, 06:33:11 am
ronnie85
  • 6
« on: March 10, 2009, 06:33:11 am »
heres my new GTD! I love it, very economical and surprisingly nippy. I want to do some tuning but first sort the problems and give it a good service.
firstly Ive got a jingling sound coming from the engine that has appeared since owning it. So thats the first to sort!!  :shock: but does anyone know what it mite be. It mainly happens on tick over it sounds like a small peice of metal is loose and vibrating or rotating against something (not a heavy mechanical banging or anything. Does anyone know what it mite be?
some photos...
Reply #1March 10, 2009, 08:12:55 am
1outof5
« Reply #1 on: March 10, 2009, 08:12:55 am »
have you checked on the exhaust pipe? heat sheild loose ?
Reply #2March 10, 2009, 08:19:38 am
arb
« Reply #2 on: March 10, 2009, 08:19:38 am »
will your digital camera do video ? you can post it to photobucket.com and we can hear it..
Where are you located ?
Reply #3March 10, 2009, 12:04:15 pm
aidan
« Reply #3 on: March 10, 2009, 12:04:15 pm »
very nice, was looking for clio turbines for mine when i had one
Reply #4March 10, 2009, 05:17:26 pm
LoneWolf
« Reply #4 on: March 10, 2009, 05:17:26 pm »
Check your timing belt cover backing plate, the big metal bit, mine was slightly buckled from a bodged timing job, it was just catching on the top pulley.
 Also check for loose clips/ fasteners and the throttle bracket on the injection pump, and keep an eye out for anything that looks like a silver powder, which could be pointing to interference with one of your pulleys.
 Welcome to the site by the way  :D
Reply #5March 11, 2009, 08:02:53 am
ronnie85
  • 6
« Reply #5 on: March 11, 2009, 08:02:53 am »
Quote from: "LoneWolf"
thanks for the welcome guys!
thanks I will check... the noise sounds like its near the cylinder head. But its one of those noises that is hard to locate where its coming from. But sounds like it could be near the timing belt area so will check that. I just hope its not inside the engine!!
Reply #6March 11, 2009, 08:50:24 am
79rabbit4dr
« Reply #6 on: March 11, 2009, 08:50:24 am »
:shock:    cleeeeeeean.... i'd get on that interior though
Reply #7March 11, 2009, 05:42:19 pm
LoneWolf
« Reply #7 on: March 11, 2009, 05:42:19 pm »
it could also be the 10mm bolts that holdthe timing belt backing plate onto the head.
 Where abouts in sunny britain are you Ronnie?
Reply #8March 12, 2009, 08:35:35 am
ronnie85
  • 6
« Reply #8 on: March 12, 2009, 08:35:35 am »
Quote from: "79rabbit4dr"
I love the interior, I just put it in! I love retro you see. Ive also got a brown dash and handles etc which I mite put in also.
Reply #9March 12, 2009, 08:36:46 am
ronnie85
  • 6
« Reply #9 on: March 12, 2009, 08:36:46 am »
I will also check here... thanks!
Im in farnham in surrey.
Reply #10March 12, 2009, 12:55:42 pm
bert
  • 423
« Reply #10 on: March 12, 2009, 12:55:42 pm »
my jetta mk2 had this noise,it was the main alternator bolt loose,the alternator was vibrating
Bert
