Author Topic: Different cooling system setup  (Read 2518 times)
June 29, 2010, 09:46:07 am
clbanman
  • 705
    Cambridge, Ontario
« on: June 29, 2010, 09:46:07 am »
I know there was a mention of electric water pumps in at least one thread but I thought I would create a new one to avoid resurrecting an old thread.   Two things started me thinking about this.  I saw a writeup on this manufacturer in ETi (http://www.ukipme.com/mag_engine.htm) and I had a loose belt due to the pivot bolt on my alternator tension bracket breaking.   My car can run for some time without alternator output but in this case with the failure, I likely didn't have much coolant flow either.
http://www.daviescraig.com.au/Electric_Water_Pumps-EWP80___Digital_Controller_Combo___Part_No_8007-details.aspx
The system uses an electric water pump but the key is the controller.   You remove the thermostat (no potential failures stuck closed) and program your target temperature.   It effectively pulses the coolant flow with reduced OFF cycle times as you approach the target temperature.   It also has an cooling cycle after engine shutdown to reduce heat soak.   Engine warm-up times should be quicker as well with less flow.  You would need to use the temperature sensor in the cylinder head to ensure proper temperature control.
It's not cheap, so... thoughts on whether this might be worthwhile?   Mind you, it's probably worth 30% of the value of my car right now.
Calvin
91 VW Golf 1.6NA 5spd
Reply #1June 29, 2010, 01:34:56 pm
Re: Different cooling system setup
« Reply #1 on: June 29, 2010, 01:34:56 pm »
whats wrong with the VW cooling system? not good enough for you? broken? i love VW cooling systems, ive never seen such a well designed cooling system. and the self purging part, pure genius..
Reply #2June 30, 2010, 07:39:38 pm
AudiVWguy
« Reply #2 on: June 30, 2010, 07:39:38 pm »
That's an interesting idea, where would you mount it? Would you need to cut off the impeller of the water pump and the pulley? I like the circulation of coolant after the engine is off idea.
Reply #3June 30, 2010, 07:42:52 pm
« Reply #3 on: June 30, 2010, 07:42:52 pm »
The operating temp only goes to -20C
Personally if I was worried I would just switch to a serp setup.
Reply #4July 01, 2010, 09:23:27 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #4 on: July 01, 2010, 09:23:27 am »
Actually it is -20 of the desired target, not an absolute measurement.
Calvin
Reply #5July 01, 2010, 09:36:35 am
arb
« Reply #5 on: July 01, 2010, 09:36:35 am »
I agree with Tyler... Serp.  If you want to improve things on the cheap, and add some life to your oil especially if you have a turbo, us the Summit oil cooler kit. Oil does a significant amount of engine cooling.
Reply #6July 01, 2010, 12:49:38 pm
« Reply #6 on: July 01, 2010, 12:49:38 pm »
I've never had a problem with the stock system.
