Author Topic: 1.6TD boost pin in AAZ  (Read 13158 times)
September 02, 2010, 08:53:45 pm
Thezorn
  • 381
« on: September 02, 2010, 08:53:45 pm »
I've heard tons about people doing this, but what does it really do? Im guessing I would get alot more fuel because of the much more agressive taper on the pin, but is that it? What type of benifits does this add as to power or effinciency.
I do have one readily availible to swap in, but Im sorta interested as to what it will ACTUALLY do for my car.
Also is this just a plug and play sort of mod? or will there be any Timing/IP tinkering needed?
Thanks,
Will
Compounded 93 AAZ
Reply #1September 02, 2010, 09:07:24 pm
sawedoffgolf
  • 213
Re: 1.6TD boost pin in AAZ
« Reply #1 on: September 02, 2010, 09:07:24 pm »
Its a drop in mod, will give you more fuel under boost. A friend of mine has it in his AAZ and likes how it can be "tuned" from conservative to aggressive in just 5 minutes.
Reply #2September 02, 2010, 09:30:52 pm
Thezorn
  • 381
« Reply #2 on: September 02, 2010, 09:30:52 pm »
okay cool, thats what I was hoping. Im guessing removal and installation is similar or exactly the same on my pump as it is with the 1.6td pump.
Compounded 93 AAZ
Reply #3September 02, 2010, 10:33:42 pm
RadoTD
  • 513
    Stage WTF
« Reply #3 on: September 02, 2010, 10:33:42 pm »
If you haven't played with your pump's fuel screw yet, it's plug and play. If you're already puking a black haze at full throttle, it'll blacken the cloud and you'll need to turn your fueling down to compensate
What it does is increases the difference in fuel from off boost to on boost, by letting the needle that rides on the boost pin run further. It'll help you set your pump up so that you don't have to go so gingerly on the throttle on low boost to keep from throwing black smoke out the back end. It doesn't change how much power you're capable of making though
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #4September 02, 2010, 11:15:00 pm
Thezorn
  • 381
« Reply #4 on: September 02, 2010, 11:15:00 pm »
So it more or less makes the amount fuel the pump puts out alot more boost responsive?
Will this mean more fuel in high boost ranges? Which is good.
Is this a good mod to do? or will it not change much?
Compounded 93 AAZ
Reply #5September 03, 2010, 10:19:39 am
RadoTD
  • 513
    Stage WTF
« Reply #5 on: September 03, 2010, 10:19:39 am »
Realistically, it means less fuel in low boost ranges. Even without the boost pin, you can turn the max fuel screw in far enough that it will give you however much fuel you wish for. The boost pin is there more to limit your fuel when you don't have boost to burn it up.
It is a good mod to do. Quick and easy and it will certainly be better.
Reply #6September 03, 2010, 10:53:49 am
Thezorn
  • 381
« Reply #6 on: September 03, 2010, 10:53:49 am »
Alright thats good enough for me then.
Thanks radoTD
Compounded 93 AAZ
Reply #7September 27, 2010, 10:35:15 pm
jpedro
  • 137
« Reply #7 on: September 27, 2010, 10:35:15 pm »
appears to me like we have a new project to take hold of.
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #8September 29, 2010, 07:30:11 am
regcheeseman
  • 714
« Reply #8 on: September 29, 2010, 07:30:11 am »
Depending on your particular AAZ pump the returns will vary and you may actually see no gains.
It is my experience with UK pumps, that some are set up so weak that the pin that follows the taper (although fitted) never moves. You could have all the taper in the world - you'll get no extra power.
And then again, I've seen AAZ pumps that will follow a GTD taper completely and then some.
Bosch thought it would also be fun to add in a max stop plate too, this restricts max fuel delivery capacity but it is adjustable externally.
Reply #9January 26, 2011, 10:57:48 am
blackbird82
  • 151
« Reply #9 on: January 26, 2011, 10:57:48 am »
the pins conical shape allows the pin riding it to move further out and give more travel to the spill collar. aka more fuel injected.
on a bosch pump with a LDA the pin is in control of maximum fuel.
On cummins engines used in Versatile tractor with a BOsch VE pump, the aneroid pin is used to set horsepower.
I love the whistle......
Reply #10January 27, 2011, 09:49:55 am
blackdogvan
  • 574
« Reply #10 on: January 27, 2011, 09:49:55 am »
Without the proper spring under the LDA diaphram it'll be a smoke show. The stock AAZ spring has a much weaker spring rate than the 1.6's giving way to much fuel at lower RPM & lower boost pressure.
1991 Vanagon 1.9 mTDI
Reply #11January 27, 2011, 02:26:35 pm
blackbird82
  • 151
« Reply #11 on: January 27, 2011, 02:26:35 pm »
weak spring eh, I got a new pin for my AAZ haven't put it in yet. Comtemplating building a new motor for it.  Its not a 1.6 pin, I'll get a pic up of it, its conical and off center, think its from a Case tractor.
got it at school when I got take these pumps apart! learn and get paid for it!
hahaha
