Author Topic: K03 turbo information  (Read 13318 times)
January 10, 2011, 05:19:12 pm
coke
  • 254
« on: January 10, 2011, 05:19:12 pm »
Looking for some information on the K03 turbocharger. My understanding is it was used on the 1.9L AAZ turbo diesel. I have been advised that the K03 would be a good turbo to use on my 1.6L NA that I plan on turbo'ing.
Now, exhaust manifold won't be a problem. Its my understanding that the TDI exhaust manifold will mate to the K03 just fine.  My issue is what to do about a downpipe.  I could use a stock downpipe, or an after-market one.  What do you guys recommend? I've noticed a few different exhaust connections (Probably diesel vs gas) and searched this forum. Found a lot of posts about people looking for downpipes, but not finding much. A quick eBay search didn't turn up much either.
Sorry for my newbish questions, but when it comes to the world of turbos, im in kindergarten. I am pretty set on the K03. A trusted source told me that the K03 would be best on an NA with a Giles pump. Just need some verification on the TDI exhaust manifold and downpipe options. Thanks guys, I _really_ appreciate it.
Reply #1January 10, 2011, 05:37:42 pm
rallydiesel
  • 1880
Re: K03 turbo information
« Reply #1 on: January 10, 2011, 05:37:42 pm »
There's lots of k03's out there. It was a turbo used on the VAG 1.8t engines. You have to be specific when dealing with turbos. The gas k03 will not be the same as the diesel k03. I don't know any particulars about it but I'm sure some people on here have used it.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2January 10, 2011, 07:20:24 pm
GEE-BEE
  • 1604
« Reply #2 on: January 10, 2011, 07:20:24 pm »
You will need a Ko3 exhaust manifold since it's different also
the intake boot is different also for the KO3 ( turbo to manifold  )
Iam have a ko4 hot side with a KO3 cold side built by gpopshop, There is a ebay seller selling new KO3 for what a ohc would cost
Techtonic's tuning can do your DP in 2.5 if you want
What platform is your install ?
GB
HERE IS A 1.9AAZ Exhaust and turbo K14 on ebay germany
150546261172
K14 downpipe
160520431381
« Last Edit: January 10, 2011, 07:27:29 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3January 10, 2011, 07:26:15 pm
coke
  • 254
« Reply #3 on: January 10, 2011, 07:26:15 pm »
Forgive my ignorance.  The K03 uses the same bolt pattern as the TDI exhaust manifold right? So I could use that?
What did you mean by platform is my install? It's going on a 1.6L NA with a Giles pump.
Is techtonic's tuning a vendor here or something?
Reply #4January 10, 2011, 07:32:34 pm
GEE-BEE
  • 1604
« Reply #4 on: January 10, 2011, 07:32:34 pm »
 270631700783
1.9 aaz Intake
Ebay germany
Installing in what body ( Platform) mki/ mkii
use a 1.9 aaz head also
Giles Pump OHC
MK1 JETTA DASH
Reply #5January 10, 2011, 07:34:45 pm
coke
  • 254
« Reply #5 on: January 10, 2011, 07:34:45 pm »
I'm just strapping a turbo onto my 1.6. Its an MK2 Jetta, 1991.
Unless I get lucky and find a turbo motor guts and all, then I'll take the time to rebuild from the bottom up.
Reply #6January 10, 2011, 07:39:48 pm
GEE-BEE
  • 1604
« Reply #6 on: January 10, 2011, 07:39:48 pm »
Techtonicstuning.com is mfg of exhaust systems and make downpipes
Mk1 1.6 td
mk1 1.9 td ( taller ) either turbo model
You will need a exhaust manifold to match the KO3, they were mfg with and without egr
I would do a  intake, exhaust all to match the
If you need a mk1 td snorkel for what ever turbo let me know
The snorkel's are different as the turbo's have different inlet size
I had to mfg the snorkel for just my application ( mk1 td airbox ) with ko3 small inlet
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7January 10, 2011, 07:41:45 pm
GEE-BEE
  • 1604
« Reply #7 on: January 10, 2011, 07:41:45 pm »
mkii snorkel ( stock) wont fit the ko3 inlet, smaller than the k14 or T3 turbo
I can make the mkii snorkel's in either size inlet, same side for the mkii airbox thou
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8January 10, 2011, 07:44:42 pm
coke
  • 254
« Reply #8 on: January 10, 2011, 07:44:42 pm »
Yeah. Hows that work, ordering from eBay germany?  Does paypal do the funds conversion and whatnot? Use google translate to communicate with the buyer?
I didn't see any MKII downpipes on the tuning site you showed.
As far as the snorken, and all that, it'd all have to be custom. I don't intend on using a stock td airbox. Probably a K&N filter or something attached to some pipe directly into the turbo.
Reply #9January 10, 2011, 09:19:25 pm
mystery3
  • 774
« Reply #9 on: January 10, 2011, 09:19:25 pm »
Germans generally speak english more fluently than americans.
Techtonics tuning often referred to simply as tt can make you a down pipe for mkII install with whatever flange for your turbo, they probably don't list the application because there isn't much interest.
Reply #10January 10, 2011, 09:28:34 pm
coke
  • 254
« Reply #10 on: January 10, 2011, 09:28:34 pm »
Ok. Well for all intents and purposes, lets assume I'm using the K03 from a 1.9L AAZ. The TDI manifold with the 3 bolt triangle flange should bolt to this turbo, right?
All that leaves for figuring out is an exhaust connection.  I'm going to go look some more but I'm having a hard time finding a K03 listed specifically for the AAZ that shows the exhaust connection so I know what to look for in a downpipe.
Reply #11January 10, 2011, 09:55:23 pm
GEE-BEE
  • 1604
« Reply #11 on: January 10, 2011, 09:55:23 pm »
Iam not sure on the TDI exhaust manifold install / KO3 fitment
Good luck
Drill/tap/ceramic coat before install
talk with Josh at Techtonicstuning
I supplied him with both manifolds and turbo's for the AAZ downpipe
2.5 s/s is the way to go
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #12January 11, 2011, 06:43:45 pm
« Reply #12 on: January 11, 2011, 06:43:45 pm »
Euro manifolds are a little harder to get this side of the pond.
Reply #13January 12, 2011, 07:31:41 am
GEE-BEE
  • 1604
« Reply #13 on: January 12, 2011, 07:31:41 am »
I got a complete intake, exhust and turbo shipped for 65.00 from gemany
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #14January 12, 2011, 12:07:59 pm
ilikevwdiesel
  • 1202
« Reply #14 on: January 12, 2011, 12:07:59 pm »
I have everything you need right here and you're welcome to drop by anytime.
My Bio
