Author Topic: Valve guide clearance? Experts needed  (Read 2185 times)
May 15, 2011, 08:41:19 am
Jory
  • 55
« on: May 15, 2011, 08:41:19 am »
I'm building a head for a 1.6NA motor. The original valve guides were worn badly beyond the point where knurling and reaming would get them back in spec, so I opted to replace the guides.
After pressing new guides in, most of the valves fit very snug, some won't even insert fully. However, two of the exhaust valves fit easily. I mic'd the exhaust valve stems and all of them measure at .312". All I can figure is that pressing the new guides in deforms them slightly, causing the inconsistent fitment.
I have access to reaming and knurling equipment, but don't know what size to knurl to. What clearance is ideal in these motors? Should I knurl and ream all of them to provide a consistent fit or just ream the ones that are tight? The wear limit of .051" seems ridiculous...
any help is greatly appreciated.
Reply #1May 15, 2011, 03:55:19 pm
Jory
  • 55
Re: Valve guide clearance? Experts needed
« Reply #1 on: May 15, 2011, 03:55:19 pm »
alright, I went ahead and reamed the guides. I just stepped up the reamer size until the valve fit easily.
When I measured the clearances, they ranged from .005"-.009", with most being in the .006-.008" range.
Is this acceptable for a diesel? I obviously don't want any more slop than I need, but I have to allow for thermal expansion.
Any input?
Reply #2May 15, 2011, 06:32:25 pm
ToddA1
  • 434
« Reply #2 on: May 15, 2011, 06:32:25 pm »
Bentley calls for 8.013mm (0.315") to 8.035mm (0.316") inside diameter.  I'm no expert; I'm quoting an A1 Bentley.
-Todd
