Author Topic: Bosch nozzles  (Read 2218 times)
April 25, 2011, 07:48:40 pm
ToddA1
  • 434
Bosch nozzles
« on: April 25, 2011, 07:48:40 pm »
Putting an order together with Rock Auto, and I notice an odd p/n with the nozzles they carry....  BOSCH Part # 0434250103 for $11.11 each.  Most other online sites list Bosch p/n: W0133-1632076...  lowest price I found was $12.95 each.
Anyone have any experience with the 103s?  Maybe Rock Auto's p/n were superseded, and they just have old stock?  They're both listed for my '81 CR, but I just want to make sure before I place the order.
-Todd
Reply #1April 26, 2011, 03:17:40 am
Mark(The Miser)UK
  • 1557
Re: Bosch nozzles
« Reply #1 on: April 26, 2011, 03:17:40 am »
I recently imported from Canada to here in the UK, 4 of these Bosch nozzles in an attempt to assemble 4 perfectly matched injectors. 8)
That part number was on the box. Made in France DN0 SN 293's. Seemed genuine old stock. However I broke one ::), two were perfect, and one has a needle too loose to operate correctly. I found an old needle which has which a better fit and a popping spray pattern.
The Bosch code 0 434 250 103 referrs to  the 293's, but so does 0 934 002 870
and  0 934 001 850, so does the code refer to alternatives, older issues, or other.
More importantly does the code always refer to the same manufacturing period, and potentially help the search for older better quality?
Having said that my nozzles at best were 75% acceptable.
Was there a drop off in French quality which led to Bosch switching to India, or was it purely monetary?
Mark-The-Miser-UK
Reply #2April 26, 2011, 04:39:35 am
ToddA1
  • 434
Re: Bosch nozzles
« Reply #2 on: April 26, 2011, 04:39:35 am »
I'm not sure what the 293s are that you're referring to, but I don't like the 75% quality rating.  I'll stick with the more common part #.
Thanks.
-Todd
Reply #3April 26, 2011, 05:26:31 pm
Mark(The Miser)UK
  • 1557
Re: Bosch nozzles
« Reply #3 on: April 26, 2011, 05:26:31 pm »
Thanks.
-Todd
The DN0 SDN293 is the model/style type of nozzle as designated to 1.6TD engines. The 1.5 qnd 1.6 engines used DN0SD193 style. However they are entirely interchangeable
Mark-The-Miser-UK
Reply #4April 26, 2011, 05:30:54 pm
ToddA1
  • 434
Re: Bosch nozzles
« Reply #4 on: April 26, 2011, 05:30:54 pm »
Learn something new every day.  I went ahead and ordered the common # nozzles.  Now I have to get to building the pop tester....
-Todd
