BOLT SIZE PLEASE ( LENGTH ) Upper alt bracket ( a/c) type
Topic: BOLT SIZE PLEASE ( LENGTH ) Upper alt bracket ( a/c) type (Read 2026 times)
August 26, 2010, 02:27:24 pm
GEE-BEE
August 26, 2010, 02:27:24 pm »
I need the correct bolt size M8 x
For the upper mount on alternator bracket, this bolt secures the alt bracket to the IP pump bracket
A/C model with serp roller tensior
Thanx GB
dealer IPC didnt show it
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
August 26, 2010, 03:20:55 pm
Mark(The Miser)UK
Re: BOLT SIZE PLEASE ( LENGTH ) Upper alt bracket ( a/c) type
August 26, 2010, 03:20:55 pm »
Not entirely sure of serpentine belts,; are they anonstandard mod? I looked on 'KATE' and could find many bolts , any of which might be the one
Why not get one that is too long and cut it to length?
Mark-The-Miser-UK
August 26, 2010, 06:54:23 pm
GEE-BEE
August 26, 2010, 06:54:23 pm »
two bottom are 8 x 85
Getting ARP 12pt as usual...
GB
Giles Pump OHC
MK1 JETTA DASH
August 26, 2010, 07:41:00 pm
August 26, 2010, 07:41:00 pm »
If I were to guess I would say M8-1.25x 40mm...I will measure it by the end of the weekend for you if no one else gets it spot on. I think you sent me the bolts when I got your old aaz bracket. Thanks again BTW
Round 2
August 26, 2010, 07:43:47 pm
GEE-BEE
August 26, 2010, 07:43:47 pm »
Let me know ?
I will send you a happy meal coupon !
Funny thing is, Iam going back to that set-up...
Cheer's Bubba !
GB
I think it's a M8 x 25 Mm
Last Edit: August 27, 2010, 04:04:48 pm by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
