Author Topic: Oil Level Sender for my 1.6TD?  (Read 3577 times)
April 26, 2006, 07:58:33 pm
« on: April 26, 2006, 07:58:33 pm »
Just like the subject heading... I'm looking to see if its feasible to install an oil level sender on my 1.6TD.
I've found that vw has oil level senders for their cars since '98 or so.  I'm guessing there could be quite possibly a ton of work involved in retrofitting one on an old diesel block.
Does anyone have any experience changing, or even holding one in their hand?  What do they look like?  My guess is that it is just some type of 'float' system.
I know this isn't really a performance enhancing upgrade, but it would would give greater piece of mind while driving down the road, knowing the engine isn't starving for oil, after say a hard run etc.  Rather than having to open the hood, and check oil level on a regular basis.
The one I checked online was for a passat, and is listed at around $100
Any info appreciated!  Thanks guys!
Reply #1May 02, 2006, 01:47:34 pm
« Reply #1 on: May 02, 2006, 01:47:34 pm »
bump. anyone?
Reply #2May 03, 2006, 03:51:37 am
TDForNow
  • 131
« Reply #2 on: May 03, 2006, 03:51:37 am »
I guess most are like me, never had the chance to fool with one.
Sorry
Alain
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #3May 03, 2006, 07:19:58 pm
« Reply #3 on: May 03, 2006, 07:19:58 pm »
Quote from: TDForNow
Sorry
Alain
no prob, thanks for the reply!  I guess I will need to do more research on oil level senders.  maybe build my own :)
Reply #4May 04, 2006, 10:09:30 am
veeman
  • 421
« Reply #4 on: May 04, 2006, 10:09:30 am »
Can you give me an example of what engine these came on? Perahps an engine code?
 I have some dealer specific engine/shop documentation that might give us some details on the systems...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #5May 04, 2006, 01:24:58 pm
« Reply #5 on: May 04, 2006, 01:24:58 pm »
they come on the 30 valve V6 in a passat. 98 and up.   New golf/jettas too I believe.  Engine code AHA/ATQ
http://parts.autopartsonlinecanada.com/parts/apocanada/wizard.jsp?year=1998&make=VW&model=PAS--004&category=A&part=Oil+Level+Sender
Reply #6May 04, 2006, 03:52:11 pm
Otis2
  • 191
« Reply #6 on: May 04, 2006, 03:52:11 pm »
I looked into this a while ago because it's such a pain to check the oil on my van.
Yeah, they came from the factory on a few German cars - BMW, Porsche and Mercedes.  Here's one from a Benz for half that price, jtanguay:
http://catalog.masterautoparts.com/item.wws?mfr=HELLA&sku=MBZ013584&price=42.88&orpartno=1537146&cookieID=1SM142BG11SM142BFZ&drillid=8&image=http%3A%2F%2Fcatimages2%2Esophio%2Ecom%2Fwebapp%2Fwcs%2Fstores%2Fservlet%2Fimc%2Fimages%2Ftn%2F1245420017%2Ejpg&clientid=masterautoparts&clientid=masterautoparts
But that kind looks like you'd have to pull the pan and do a fair amount of fiddling to get it working.
An easier solution would be a simple float switch, like this one that replaces the oil drain plug:  http://www.aircraftextras.com/LowOilSensor.htm
Or higher tech would be a replacement for the factory dipstick, like these ones:
http://www.siemensvdo.com/products_solutions/powertrain/sensors/powertrain/oil-level-sensors/passive-electrothermic-oil-level-sensor.htm
or
http://www.emp-corp.com/html/products/advanced/oil_mgmt/level_sensors.htm
Not sure if this one replaces the dipstick or not:
http://www.siemensvdo.com/products_solutions/special-oem-solutions/sensors/oil-level-sensor/oil-level-sensor.htm
If you experiment in this direction, I'd love to hear the results.
Reply #7May 04, 2006, 04:52:10 pm
« Reply #7 on: May 04, 2006, 04:52:10 pm »
EMP advanced products.   I cant wait until they release their electric high flow oil pump.  I've been waiting for a while now :)
Imaging pre and post lubrication?  no need for a turbo timer :)
I was also considering their electric waterpump.   Our motors would heat up faster as well if the coolant was just 'sitting' in the head :)  might put a bit too much load on the alternator though.  And $400USD later... although the american dollar is only $1.10 cdn now :)
what the heck is their Oil Mate?  Hmm... burns bad oil... introduces clean oil into the bad oil.... interesting... (on EMP website)
The VDO dipstick replacement seems very interesting...  Thats the one I would want!  But where to buy?
