Author Topic: id my turbos  (Read 3470 times)
May 07, 2006, 06:03:37 pm
dennis m king
  • 36
id my turbos
« on: May 07, 2006, 06:03:37 pm »
i got a turbo that says garrett AIResearch bbc 42 with a m24 on the compresser housing
and one that just has AIResearch m27 on the compresser.
are these t3s or t2s or the k numbers i see you guys talk about?
and are they good for what boost with out stupid fueling?
http://68.57.30.180/images/turbo5.jpg
http://68.57.30.180/images/turbo13.jpg
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
Reply #1May 07, 2006, 06:24:27 pm
id my turbos
« Reply #1 on: May 07, 2006, 06:24:27 pm »
i can't say much with out seeing the turbine side, but the second one looks very small.
Reply #2May 07, 2006, 06:30:09 pm
dennis m king
  • 36
id my turbos
« Reply #2 on: May 07, 2006, 06:30:09 pm »
in person the inlets are the same diameter.
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
Reply #3May 07, 2006, 08:13:10 pm
Kudagra
  • 738
    • www.no-coast.com
id my turbos
« Reply #3 on: May 07, 2006, 08:13:10 pm »
T3s
KKK turbos have a triangle with the 3Ks in it.
Air research is Garrett I believe after about 1986.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #4May 07, 2006, 08:38:44 pm
vwmike
  • 1158
id my turbos
« Reply #4 on: May 07, 2006, 08:38:44 pm »
They're both T3's...but if I could see the rest of the turbos I might be able to tell you the applications.
Reply #5May 07, 2006, 11:03:49 pm
Benjamin
  • 485
id my turbos
« Reply #5 on: May 07, 2006, 11:03:49 pm »
where did you get those turbo, from wich car...
Greetz, Benjamin
Must make +250hp
Reply #6May 08, 2006, 02:21:06 pm
dennis m king
  • 36
id my turbos
« Reply #6 on: May 08, 2006, 02:21:06 pm »
the garret airesearch is from a 83 td quantum but i can not say it is oem. the other was suposidly from a mid 80s td jetta. the unit in my 86 jetta is from the 83 quantum. i am betting the one that just says airesearch is the older one. i have 3 turbos two say garrett air and one just air. and one 1.6 td that says MD on the id boss on the block    out of a 90s quantum that i think should of been a 1.9L
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
Reply #7May 09, 2006, 01:32:06 pm
VwPodRacer
  • 22
id my turbos
« Reply #7 on: May 09, 2006, 01:32:06 pm »
.... :twisted:
