Author Topic: AAZ pump vs 1.6TD  (Read 3275 times)
October 25, 2010, 06:37:37 am
dieselherb1
  • 354
AAZ pump vs 1.6TD
« on: October 25, 2010, 06:37:37 am »
What is the difference between the AAZ  and the 1.6TD pump?
Also can a camplate from a ALH pump be used in a AAZ(MTDI) pump?
Thanks
Reply #1October 25, 2010, 07:37:49 am
smutts
  • 720
    ClackClackClackClackClack
Re: AAZ pump vs 1.6TD
« Reply #1 on: October 25, 2010, 07:37:49 am »
The AAZ pump nose is longer so the bearing is bigger, this is to fix the earlier pumps getting wobbly. I bet you the TD pulley is wobbly. I don't know if the later pump's pulley is offset to compensate.
Reply #2October 26, 2010, 06:29:51 pm
dieselherb1
  • 354
« Reply #2 on: October 26, 2010, 06:29:51 pm »
More info
Reply #3October 27, 2010, 05:50:46 pm
« Reply #3 on: October 27, 2010, 05:50:46 pm »
Cam plates are definitely different between the various applications.  1.6TD pumps have a different ramp shape than AAZ pumps since 1.6TDs have different injectors than AAZs.
Other differences... AAZ has the almost-pointless LDA pin whereas most 1.6TDs have a fairly aggressive pin.  AAZ pumps often have a myriad of different emissions control bits and pieces depending on the application, and may have an immobilizer attached to the fuel solenoid.
I'd almost bet money that the governor kicks in at a lower RPM on the AAZ pumps...  Would be a fairly safe bet that the load-dependent advance kicks in at a different RPM too.
That help?
Reply #4October 28, 2010, 07:19:07 pm
dieselherb1
  • 354
« Reply #4 on: October 28, 2010, 07:19:07 pm »
I was wondering if the 1.6TD pump would be a better starting point for a MTDI(w/TDI camplate)?
« Last Edit: October 28, 2010, 07:21:07 pm by dieselherb1 »
Reply #5October 29, 2010, 03:17:39 pm
regcheeseman
  • 714
« Reply #5 on: October 29, 2010, 03:17:39 pm »
Dunno where you are from, but the US 1.6 pumps differ considerably from most UK/European 1.6 pumps.
As a consequence, a lot of info on here can be misleading.
In my experience, most of the UK 1.6 pumps have the AAZ/GTD style camplate, I've only ever seen one of the lame 1.6 camplates that seem to be universal in the US.
Reply #6October 30, 2010, 08:51:06 am
« Reply #6 on: October 30, 2010, 08:51:06 am »
interesting
