Author Topic: Eco Dual Fan (where can I get a belt?)  (Read 2636 times)
October 28, 2010, 04:54:56 pm
dropdtop
  • 37
« on: October 28, 2010, 04:54:56 pm »
Somehow amongst the rebuild I lost my belt for the dual fans,,,  anyone got a part number where maybe the napa/autozone/murrays/etc etc.. may have a replacement?
thanks,
Brad
Reply #1October 28, 2010, 06:04:26 pm
Quantum TD
  • 1195
Re: Eco Dual Fan (where can I get a belt?)
« Reply #1 on: October 28, 2010, 06:04:26 pm »
I doubt that any of those places would have it, or have a listing for it. The ECOdiesel is virtually unknown by parts catalogs.
But, the fan and shroud is the same as used on the VR6 Corrado. Try your local CarQuest dealer with this part number:
1H0 119 137 A
You should be able to get it for about, or under $10.
Actually, now looking at the application list, this belt fits alot of different VWs. So, it should be pretty easy to find (maybe not at O'Pile-ees, Vatozone or (payday) Advance).
Reply #2October 28, 2010, 07:49:42 pm
dropdtop
  • 37
« Reply #2 on: October 28, 2010, 07:49:42 pm »
Thanks, i will try that number and I totally agree with it not being in the parts books... I hate even askin for a air filter for it. have to always bring in my old one to match it up.
I got a corrado fan shroud,, and a motor from a jetta (4pin) and for some reason the shround doesnt line up with my existing bolt holes.. almost like the shrouds is just a tad narrower (1 inch) then the radiator I have now??
EDIT:   found out my dad must have removed those 1" tabs that were originally installed UGHHHHH
« Last Edit: October 28, 2010, 08:05:24 pm by dropdtop »
Reply #3October 28, 2010, 09:01:56 pm
« Reply #3 on: October 28, 2010, 09:01:56 pm »
Yeah I know the '95 passat VR6 has a goofy little fan belt, seems like it would be the same on all of 'em.
Reply #4October 28, 2010, 11:55:26 pm
Quantum TD
  • 1195
« Reply #4 on: October 28, 2010, 11:55:26 pm »
That's probably because these were the only cars that used this rad fan setup (1991-1992 ECODiesel, and 1990-1993 Corrado VR6), at least in the USA.
As you've noted, the fan motor has the 4-terminal plug for a 3-speed fan, but only the correct fan will fit into the shroud and clear the radiator.
Unless the motor you have came from either of those 2 cars, I'm afraid that even if you get the motor mounted, it will hit the radiator or cause problems down the road.
Another thing to consider: you said you got the shroud from a Corrado. Was it a VR6 Corrado? The G60 (4 cylinder motor) and the VR6 used two completely different shrouds and motors.
Regarding the filter, just look up the air filter for the same year make and model, but with a 1.8 gas motor. They're exactly the same.
« Last Edit: October 28, 2010, 11:58:09 pm by Quantum TD »
Reply #5October 29, 2010, 01:17:51 am
GEE-BEE
  • 1604
« Reply #5 on: October 29, 2010, 01:17:51 am »
I have a extra radiator  as shown ( new ) MKII scirocco a/c type
675 mm used for fitment of intercooler install
50 shipped
GB
« Last Edit: October 30, 2010, 06:55:02 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6October 29, 2010, 09:28:29 am
« Reply #6 on: October 29, 2010, 09:28:29 am »
1H0 119 137 A
i seriously almost peed a little when i read that.. funniest thing ive heard in a while..
