Need help with engine ID
Topic: Need help with engine ID (Read 2318 times)
January 06, 2009, 10:59:54 am
veedubcanuck
January 06, 2009, 10:59:54 am »
How can I tell what engine I have when the ID area of the block is pitted too bad to read? The engine is not in a car so I don't know what it was I . It is a 1.6TD from somewhere around 83?? What can I look at to tell?
Thanks
January 06, 2009, 11:09:47 am
veedubcanuck
January 06, 2009, 11:09:47 am »
From the number on the pump it looks like it was from an 83-84 rabbit. I think the guy it was from also said it was a rabbit now that I think of it.
January 06, 2009, 01:05:01 pm
January 06, 2009, 01:05:01 pm »
well im pretty sure the model of the car doesn't make a huge difference...
You want to know if its like MF or something?
I would clean the area with lacquer thinner where it's supposed to be printed and then put paper over it and with a black sharpie (the wedge kind) just lightly shade over it and you might be able to make it out that way?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
January 06, 2009, 01:11:01 pm
veedubcanuck
January 06, 2009, 01:11:01 pm »
Yes, that is what I am after. There is no way to read what was there, I wire brushed, scraped, and then used my small sandblaster to get the rust away and there is no hope of getting anything from there....
January 06, 2009, 01:13:12 pm
January 06, 2009, 01:13:12 pm »
Sh!tty.... Hmmmmmm.
well you could start listing the parts on it? Hahaha
like the number off the injection pump, what turbo you have, and so on. Maybe post a pic too? There are a few guys on here who know VWs like the back of their hand.
THROWN ROD
January 06, 2009, 01:41:17 pm
TurboJ
January 06, 2009, 01:41:17 pm »
One of those and an angle grinder worked for me
Jetta II 1.6 TD 'Project 200'
