Author Topic: Newbie from the UK  (Read 4516 times)
June 27, 2006, 04:41:18 am
caddyjoe
  • 3
    • http://www.tidyvag.co.uk
Newbie from the UK
« on: June 27, 2006, 04:41:18 am »
Hello everyone,
My name's Joe i'm from Bournemouth, England.  Some of you may know me from the caddy forum.  Marteen sent me over here as I'm a bit of a diesel convert.
Here's a couple pics of my caddy.  Its an '89 Caddy which I have fully rebuilt mechanically and I fitted a 1.9TD AAZ froma mk3 Golf that I was breaking.  I fully rebuilt the engine, including fitting new cylinder head and injector pump.  I also fitted the larger Garrett turbo from my old 1.6TD engine as well as the boost pin/adjustable LDA from the 1.6TD pump.
I still haven't fitted the front mount intercooler or cranked the boost, but she goes very well all the same.  I'm in the process of sorting the bodywork so within a couple of months she should be finished, but its my daily drive so I have to do things when I can.  But when she is finished I'm going to build a mk2 with a PD.
Anyway this forum has some great info, look forward to talking to some of you in the near future.
Joe
Reply #1June 27, 2006, 08:26:57 am
regcheeseman
  • 714
Newbie from the UK
« Reply #1 on: June 27, 2006, 08:26:57 am »
Hello Joe,
Love the Caddy - it's very low.  :wink:  :lol:
Reply #2June 27, 2006, 09:43:52 am
caddyjoe
  • 3
Newbie from the UK
« Reply #2 on: June 27, 2006, 09:43:52 am »
The sump is too fricking low!  Thats why I had to replace it on saturday!  :P
Reply #3June 27, 2006, 07:13:13 pm
mk1vdub
  • 93
Newbie from the UK
« Reply #3 on: June 27, 2006, 07:13:13 pm »
Hello mate :D
nice to see another from the UK, theres actually quite a few of us now 8)
that is one sweet caddy :mrgreen:
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
Reply #4June 28, 2006, 01:57:30 am
regcheeseman
  • 714
Newbie from the UK
« Reply #4 on: June 28, 2006, 01:57:30 am »
last few weeks there seems to have been a glut of people on the Caddy forum from the UK asking questions about TD conversions - I've stuck my oar in on most occassions and told them to get over here.
Reply #5June 28, 2006, 07:52:40 am
mk1vdub
  • 93
Newbie from the UK
« Reply #5 on: June 28, 2006, 07:52:40 am »
cool, TD is the way to go! it just make so much sense, and I reckon suits a caddy down to the ground 8)
this certainly is THE place for diesel info, I've learnt a hell of alot, and hopefully given back a little too :P
I'd love to find out exactly how many in the UK are running turbo diesels now( obviously not standard new tdis there loads of them :roll: ) maybe organise a meet, there are a few tdi swaps out there which I'd love to have a look at/ get a passenger ride in :D
so what stage are you at now reg - whats your next thing to do?
1983 mk1 golf GTD
Reply #6June 28, 2006, 07:59:05 am
regcheeseman
  • 714
Newbie from the UK
« Reply #6 on: June 28, 2006, 07:59:05 am »
Get the FASKING THING to fire would be nice!
Don't think the starter motor is up to it.
I'm gonna have to move the battery back 25/30mm to get the pipes from FMIC to turbo fitted and that's my work done in the engine bay (hopefully)
Reply #7June 28, 2006, 10:43:11 am
mk1vdub
  • 93
Newbie from the UK
« Reply #7 on: June 28, 2006, 10:43:11 am »
yeah I had to do the same thing for my boost pipes.
just a few suggestions to throw out there for starting:
test your glow plugs, check they're definatley glowing
check the stop solenoid
are you on flat ground? I've actually had problems starting after being on a hill the wrong way, and fuel running back to the tank
have you had your injectors pop tested?
timing all checked
cold start working properly if your using it?
and a really good battery
good luck :D
1983 mk1 golf GTD
Reply #8June 29, 2006, 02:02:35 am
regcheeseman
  • 714
Newbie from the UK
« Reply #8 on: June 29, 2006, 02:02:35 am »
They
were before I fitted them, they draw current and the glow plug circuit works fine now.
Couldn't shift it from the pump body but it clicks and fuel it getting through
on the level.
No - I've a spare set of good NA injectors and pump though.
timing all checked
Yep, checked, double checked and then checked again
I'm not using it, but it does appear to work correctly from external inspection
I tried a 100% battery last night, the starter is slow and I need to get a diesel one.
Reply #9July 01, 2006, 03:22:08 am
Baxter
Newbie from the UK
« Reply #9 on: July 01, 2006, 03:22:08 am »
Just had to get in with the "Im in the UK and I got a Diesel Caddy thread!"
Reg, seems like your a bit further on than me! Im still driving around with the 1.6D and it's up at 265 K now! Living on borrowed time I think!
For you caddy boys I have a few Caddy related items on my website at www.brickwerks.co.uk It's mainly T3's I specialise in but Caddys do darken my doorway every now an again.
Reply #10July 11, 2006, 11:07:31 pm
fil1973
  • 6
Newbie from the UK
« Reply #10 on: July 11, 2006, 11:07:31 pm »
just joined from uk too, & i run a vento td[/img]
Reply #11July 14, 2006, 03:20:20 pm
madmatt
  • 24
Newbie from the UK
« Reply #11 on: July 14, 2006, 03:20:20 pm »
hi another newbie from uk also into t3's (hi simon)i have a pick up with an upright 19n/a at the moment but this set up gives more scope for turbos and manifolds than standard and a van with a19 aaz
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
Reply #12November 12, 2006, 02:07:07 pm
smutts
  • 720
    ClackClackClackClackClack
Newbie from the UK
« Reply #12 on: November 12, 2006, 02:07:07 pm »
Greetings from deepest darkest Devon, UK.
Got a 91 Golf GTD, 200,000miles, so I bought another one. Superb tools.  This forum is the only place on the web for any decent info on these things.  Keep up the good work :D
Reply #13November 12, 2006, 11:34:55 pm
bert
  • 423
Newbie from the UK
« Reply #13 on: November 12, 2006, 11:34:55 pm »
Hi guys,and joe,just done exactly the same as you thanks to mk1vdub and the others off here,for getting me motivated  :wink:
lets sort a meet out for next summer  :)
Bert
