Author Topic: Coldness sets in  (Read 2831 times)
November 19, 2006, 04:07:51 pm
BellCityDubber
  • 251
Coldness sets in
« on: November 19, 2006, 04:07:51 pm »
Well, it's that time of year again...
I've recently been plugging in my diesel at night and firing it over in the morning isnt so bad.
Today I neglected to plug it in, and I've been having a heluva time starting it.
I would more than likely need new glow plugs right?
Reply #1November 19, 2006, 04:25:03 pm
Coldness sets in
« Reply #1 on: November 19, 2006, 04:25:03 pm »
either glow plugs or new piston rings
Reply #2November 19, 2006, 04:28:21 pm
BellCityDubber
  • 251
Coldness sets in
« Reply #2 on: November 19, 2006, 04:28:21 pm »
Quote from: Trev0rbr
yep, must be glow plugs.
if it were piston rings I'd be seeing alot more symptoms would I not?
Reply #3November 19, 2006, 06:55:29 pm
Coldness sets in
« Reply #3 on: November 19, 2006, 06:55:29 pm »
it's hard to say, my rabbit ran really good and started really nice but it had alot of blow by.  it depends how it is hard to start too, and what it does when it starts... does it miss alot. does it take alot of cranking to start, does it crank fairly quickly... you know.
Reply #4November 19, 2006, 07:01:22 pm
Slave2School
  • 531
Coldness sets in
« Reply #4 on: November 19, 2006, 07:01:22 pm »
What oil are you using?
2002 ford focme wagon
Reply #5November 19, 2006, 08:36:36 pm
Coldness sets in
« Reply #5 on: November 19, 2006, 08:36:36 pm »
my old jetta had a rough time starting at anything below -15C... thats with cold start pulled all the way too..
it had new rings put in, but pistons were a bit sloppy.  glow plugs worked.
i think its safe to say that white smoke could mean that you may need new rings or compression is low.  white smoke might also be bad injectors though...  one thing is for sure.  an engine with low compression will not start without GP's.  it seemed as though the motor would not even attempt to fire.
oil makes a huge difference too.  thick oil will reduce cold cranking speeds by a whole lot.  i think everyone here will agree that switching to 0w40 is a great idea in the winter.
my first winter with a diesel, i went to a buddy's house, and that night the temps dropped to -30 or -35ish.  the battery was alright, but the engine was cranking over very slowly.  i had to leave it there and wait for a boost.  even with a boost it cranked pretty slow.  (the block heater was connected, but i think there was something wrong with the wire because it did not seem to be working  :x )
needless to say i got pretty pissed with diesels, but i have grown to love the sound, and the mileage :).  make sure you have a 1000CCA battery if your car has low compression, and check the GP's.
Reply #6November 19, 2006, 10:29:36 pm
BellCityDubber
  • 251
Coldness sets in
« Reply #6 on: November 19, 2006, 10:29:36 pm »
I'm putting my money on glow plugs.
my jetta hadn't run since the night before, wouldnt start for me in the afternoon... or early in the evening, so then I plugged it in for about a half an hour and it fired up nicely.
