Author Topic: O-ringed head/block?  (Read 2838 times)
July 06, 2008, 10:24:03 pm
the4ork
  • 331
« on: July 06, 2008, 10:24:03 pm »
has anyone tried it?
is it better to do the block or the head?
im considering trying it, i know a machine shop that can do it at an apetizing price...
i dont want to do the head b/c i want to have the combustion chambers ceramic coated, i'd rather do just the block.
with the metal headgasket
30+ psi here i come
any imput?
Reply #1July 07, 2008, 03:44:13 am
blkboostedtruck
  • 1535
« Reply #1 on: July 07, 2008, 03:44:13 am »
it's been done! i think andy2 did it? do a search it might be under compound set up?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2July 07, 2008, 06:16:17 am
gigaz2
  • 626
« Reply #2 on: July 07, 2008, 06:16:17 am »
hasn't he concluded that the head can't seal with only 4 bolts per cylinder being subjected to those pressures?
I believe that is in the end of that thread.
Reply #3July 07, 2008, 08:51:44 am
the4ork
  • 331
« Reply #3 on: July 07, 2008, 08:51:44 am »
so it sealed no better than a metal gasket with studs i would guess?
Reply #4July 07, 2008, 06:10:07 pm
andy2
« Reply #4 on: July 07, 2008, 06:10:07 pm »
The problem is not the factory head bolts or the steel multi layer gasket.The cyl head will actually flex between the headbolts causing combutsion leakage.
Reply #5July 07, 2008, 06:16:32 pm
andy2
« Reply #5 on: July 07, 2008, 06:16:32 pm »
We would need an iron cyl head and have long studs that go through the head and block right down to the main bearing caps.This will take the stress off the block as the deck of the block would be the next weak link.
Reply #6July 07, 2008, 11:27:48 pm
the4ork
  • 331
« Reply #6 on: July 07, 2008, 11:27:48 pm »
so at what pressures are we having problems with flex and combustion leakage?
Reply #7July 08, 2008, 05:17:24 am
MJF
  • 581
« Reply #7 on: July 08, 2008, 05:17:24 am »
Quote from: "the4ork"
You need high enough cylinder pressures for that, it´s not the boost. I´ve never had any kind of head gasket problems, but I had only 230hp/37psi/24+:1 compression.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #8July 08, 2008, 03:43:16 pm
andy2
« Reply #8 on: July 08, 2008, 03:43:16 pm »
Its really the High torque/cyl pressures that cause the issue.The longer stroke 1.9L can make much more torque and at lower rpm when compared to the 1.6 this is why the 2 engines have different results when they are modified.
Reply #9July 10, 2008, 12:33:45 pm
myke_w
  • 1099
« Reply #9 on: July 10, 2008, 12:33:45 pm »
Quote from: "MJF"
I think I found my new signature  :D
