Author Topic: Removing intercooler on 1600 td  (Read 2127 times)
December 31, 2006, 05:13:09 am
DELETED
« on: December 31, 2006, 05:13:09 am »
DELETED
Reply #1December 31, 2006, 05:38:57 am
DELETED
« Reply #1 on: December 31, 2006, 05:38:57 am »
hmmm nice project!
you should probably turn the fuel down if you're not going to intercool it.  if you are going to intercool it, just use some kind of small pump, and a misting system (spray mist of water on the intercooler fins), and make sure that you have ducting to the atmosphere (the water will evaporate out... this way is very efficient as water takes a lot of heat when it evaporates) but if you don't have the stock intercooler, simply buy an air/water intercooler and get a bilge pump or something... that thing would be soooo cold!!!
for a motor that sat for 12 years, changing the oil would be the first thing.  if you're changing the rings, then thats a really good idea. inspecting the turbo would be 2nd.  how is the shaft play?  usually you let the motor idle for about 10-20 seconds, then lightly load it as if you were driving... remembering not to overload the turbo when its cold.  when the oil pressure builds up and starts lubricating the turbo properly, it will make that nice whine that lets you know its working :)  NEVER beat on a cold turbo!!!
Reply #2December 31, 2006, 06:42:37 am
DELETED
DELETED
« Reply #2 on: December 31, 2006, 06:42:37 am »
DELETED
Reply #3December 31, 2006, 02:31:36 pm
DELETED
« Reply #3 on: December 31, 2006, 02:31:36 pm »
hmmm that arrow seems to be pointing to some sort of manufacturing date... not sure though.
about the cheap oil...  the only real time that your engine will burn oil is under a large load (hard accelerating).  if the engine will only see 3000-3500pm gradual acceleration, the soot levels and oil burning should be kept to a minimum.
if you really want this motor to last forever, i would suggest checking out the fs-2500 bypass filter.  it will save you lots of time changing the oil especially since you can't just go under the boat  :wink:
www.fs2500.com
a quick run-down of how the bypass filter works, is that it is a low flow filter that pretty much cleans all the black soot out of the oil (basically taps into the high pressure oil gallery like a pressure gauge would).  All you need to do is change the filter at around 10'000km or i believe 850 hours, and top off any fluid.
i'm currently biding my time waiting to get one off ebay.  I will run a good synthetic year round (the filter media is approx $23).   I'm not affiliated with them whatsoever, but I am just throwing this out there since it's a really good product, and gets rid of that nasty soot in the oil.
you said you were going to give the motor new rings correct?  I think you may also want to check out www.totalseal.com for their total seal rings. most people who buy them love them, and report no more blowby :)
