Author Topic: drag racing at santa pod  (Read 13084 times)
April 13, 2008, 01:52:31 pm
oldskool rich
  • 446
« on: April 13, 2008, 01:52:31 pm »
just been down santa pod today,
took the caddy on the quater mile 8)
the crowd all stood up for my 2nd gear burn out at the start line, first ever run, golf vr6 pulls away and gets a 10 yard head start, as i spazed up the revs in first gear :oops: , then into second and i shot passed him, continued to pull away, ended up beeting him by about 50 yards :lol:
the track was wet and no one got any good times. not only did i beet a vr6 but also beet regal's 350bhp 18t mk5 golf :wink:
my set up cud of been alot better and i over reved it like crazy, i never realised till afterwards that all my torque is down low,
has anyone got any idea exactly where the power band starts and finishes? whens best to change gear on a super high boost aaz?
the quater mile is amazing, id recomend it to anyone
f6squared I.D.S.T
Reply #1April 13, 2008, 01:58:33 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: April 13, 2008, 01:58:33 pm »
Any tuned engine has a different powerband. Best way to know what it looks like is on a dyno.
Reply #2April 13, 2008, 02:07:48 pm
oldskool rich
  • 446
« Reply #2 on: April 13, 2008, 02:07:48 pm »
 8)  8)  8)  8)  8)
i cant afford to get it dynod, that would cost more than my whole car :cry:
ill just have to practice untill i get it right. im pretty sure its 3200-4400ish, but i was shifting at 6000 :shock: way too high, still did ok though
i need a better clutch, anyone know of any cheap race clutches in the UK?
f6squared I.D.S.T
Reply #3April 13, 2008, 02:16:11 pm
Baselyne
« Reply #3 on: April 13, 2008, 02:16:11 pm »
NICE WORK BEATING A VR
YOU MAKE ME PROUD ROLLING THE 4 BANGER DIESEL
nice style
Reply #4April 13, 2008, 11:15:26 pm
MJF
  • 581
« Reply #4 on: April 13, 2008, 11:15:26 pm »
Quote from: "oldskool rich"
How expensive dynoing is there :shock: It´s 40-50€ here.
Any times/trapspeeds :?:
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5April 13, 2008, 11:59:31 pm
carrizog60
  • 978
« Reply #5 on: April 13, 2008, 11:59:31 pm »
videos please 8)
Portugal
Reply #6April 14, 2008, 02:47:28 am
oldskool rich
  • 446
« Reply #6 on: April 14, 2008, 02:47:28 am »
its about £60 to get it dynod here, which is what my whole engine cost me :lol:
poverty :roll:
my best time was 16.4 but i am so sure i cud knock more than a second off that, and if my set up was better i cud probly bring it down pretty close to the 14s + the track was clearly wet too
f6squared I.D.S.T
Reply #7April 14, 2008, 05:05:09 am
nogama3
  • 162
« Reply #7 on: April 14, 2008, 05:05:09 am »
mate, have you tried stealth racing in warwick, vince is a cool dude. give him a ring.
whereabouts in coventry are you?
i am from nuneaton and have an aaz in my mk3. i was due to go to santa pod but the weather forecast put me off.
what work you done to your motor then?
Reply #8April 14, 2008, 10:50:56 am
bert
  • 423
« Reply #8 on: April 14, 2008, 10:50:56 am »
i was going to go with the mk1 golf owners club but too the weather put me off  :(
Bert
Reply #9April 14, 2008, 11:17:13 am
« Reply #9 on: April 14, 2008, 11:17:13 am »
i would say that your max torque is going to be when you can reach max boost.  so probably around 2800-3200 rpm.
max hp however will be wayyyy up there near or at redline.
Check out the 1.6 power figures.  definitely not 1.9, but should give you an idea.
and congrats on beating a vr6 & 350 hp 1.8T  :shock: and the fact that you haven't put much money into that beast is even more incredible!!!  8)
Reply #10April 14, 2008, 12:51:25 pm
oldskool rich
  • 446
« Reply #10 on: April 14, 2008, 12:51:25 pm »
http://s85.photobucket.com/albums/k75/Jonny_777/?action=view&current=TheDeathCaddy.flv
not a very clear video but you get the idea, ill try to get the one of me against a vr
Quote from: "nogama3"
im in walsgrave.
gov mod, gtd boost pin (very modified), 11mm pump piston
garret T3 with blocked waste gate 40-50psi, tdi crank shaft, clutched alternator, electric fuel pump to feed my thirsty pump, merc nozzles. to name a few :lol: .
f6squared I.D.S.T
Reply #11April 14, 2008, 01:48:33 pm
carrizog60
  • 978
« Reply #11 on: April 14, 2008, 01:48:33 pm »
cant see smoke... :?:
you should try on lauching on a taller gear,that was too short... :idea:
Portugal
Reply #12April 14, 2008, 02:02:52 pm
Reply #13April 14, 2008, 03:03:23 pm
  • 656
« Reply #13 on: April 14, 2008, 03:03:23 pm »
A T3 can't push 40-50 psi. At those levels of boost the head wouldn't stick on the block for long.
Reply #14April 14, 2008, 03:52:58 pm
oldskool rich
  • 446
« Reply #14 on: April 14, 2008, 03:52:58 pm »
Quote from: "Black Smokin' Diesel"
well tbh im just guessing, my gauge only goes up to 30, and it shoots off the gauge in about 2 seconds increadibly fast, the actuator is totaly disconected, it seems to be ok i dont go full thottle for more than a few seconds just to be safe. i was under the impression that the more fuel i throw in the more boost i get and theres certainly plenty of fuel.
if anyone knows how much boost im hitting with my fuel mods id be interested. i still recon around 40+
f6squared I.D.S.T
