Author Topic: 1.9 TD timing belt sprocket  (Read 3219 times)
April 03, 2008, 02:14:11 am
Torchd
  • 372
« on: April 03, 2008, 02:14:11 am »
Hey ppl!!
I read about the timing sprocket problem in 1.9td engines....  nothing has happened to my engine untill now...  the engine is from a 97 golf so it prolly has the new type 12 point bolt..  but i heard thats not the rite cure and the bolt still breaks...
proper pix is known to be the TDI pulley and bolt...  please tell me how its done and what are the parts needed from which VW TDI motor to perform this job?!!
Thanks!!
Reply #1April 03, 2008, 03:47:09 am
« Reply #1 on: April 03, 2008, 03:47:09 am »
Bolt and sprocket from 1Z or AHU.
Reply #2April 03, 2008, 04:31:30 am
Torchd
  • 372
« Reply #2 on: April 03, 2008, 04:31:30 am »
Thats alll??
will i have to do anything to my crankshaft??  cuz i dont wana take it out of the motor...
i just checked out the existing bolt...  its a 12 point but it says 10.9 on the head...  where as according to QuickTD on vwvoxtex (http://forums.vwvortex.com/zerothread?id=1017820)
The older bolts should be 6 point and 10.9 or 9.8.
Wheres newer stronger bolts are 12 point and 12.9 shud be written on top.
So im confused!!
Reply #3April 03, 2008, 05:57:06 am
« Reply #3 on: April 03, 2008, 05:57:06 am »
Oh yes, you have to get it welded up, then machined down to fit the new sprocket.
Reply #4April 03, 2008, 11:23:52 am
slorimer
  • 52
« Reply #4 on: April 03, 2008, 11:23:52 am »
Or if your lucky, some late model Mk IIIs have both the key and the flat so either crank sprocket will fit.  The one issue I heard with just switching to the TDI sprocket is that its position limits your pump adjustment because it puts you at the ends of your elongated holes in the pump attachment brackets.
94 1.9TD
Reply #5April 03, 2008, 07:47:05 pm
g-spec
  • 289
« Reply #5 on: April 03, 2008, 07:47:05 pm »
You can also have some dowel pins installed.....I did this on my TD without taking the crank out.....I know its not the best solution but its cheaper than remachinging the crank and it adds more security along with a new bolt and pulley!!!
Reply #6April 03, 2008, 08:36:37 pm
Re: 1.9 TD timing belt sprocket
« Reply #6 on: April 03, 2008, 08:36:37 pm »
Quote from: "Torchd"
Hey ppl!!
Thanks!!
I personally feel that a fresh sprocket, properly-torqued fresh bolt, and the addition of the one-way clutch pulley on the alternator should make a stock crank hum just fine.
Assuming that the sprocket has never loosened in the past and the crank is in perfect shape !!
Since you can't be sure what  bolt the PO used, nor can you be sure it was torqued correctly, it's probably wise to start over yourself with fresh parts.
Reply #7April 03, 2008, 11:02:44 pm
Torchd
  • 372
« Reply #7 on: April 03, 2008, 11:02:44 pm »
Thanxx guys!
So can someone give me part numbers for the following parts..
Bolt and sprocket from AHU or 1Z engine
Bolt and sprocket from AAZ engine.
One way clutch alternator pulley.
Reply #8April 18, 2008, 03:15:49 am
Torchd
  • 372
« Reply #8 on: April 18, 2008, 03:15:49 am »
Guys...?
Can anyone help me wid daa part numbers please?!!!
