Author Topic: What k14 am I looking for?  (Read 2437 times)
April 21, 2008, 06:09:18 pm
bugnut
  • 89
« on: April 21, 2008, 06:09:18 pm »
What k14 turbo should I be looking for.  I am rebuilding a stock 1.6td.   This will go into my 80 rabbit and just used as a daily driver.  No racing and no mods done to the engine.  I heard the 1.9 k14 turbo is different than the 1.6 version.  Should I just stick with the 1.6 since I am going to be all stock?  And if so what turbo part number should I be looking at
Thanks Brian
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #1April 22, 2008, 02:19:20 pm
flapjack
  • 283
« Reply #1 on: April 22, 2008, 02:19:20 pm »
this one is off of a 1.6TD eco-diesel
I THINK I read that it has the smaller impeller, but I don't know for sure
signature
Reply #2April 22, 2008, 07:11:33 pm
« Reply #2 on: April 22, 2008, 07:11:33 pm »
AAZ compressor is 5cm across the bottom, 3.48cm at the top of the blades.
Reply #3April 22, 2008, 11:45:56 pm
bugnut
  • 89
« Reply #3 on: April 22, 2008, 11:45:56 pm »
So I am now looking for these turbos.  068145704d or the 028145703e.  It all depends on if I want the larger compressor wheel or not.
Reply #4April 22, 2008, 11:59:28 pm
dogday
  • 37
« Reply #4 on: April 22, 2008, 11:59:28 pm »
Quote from: "bugnut"
Ok dumb question #49 (in an open ended sequence...)
I'm still getting up the curve on everything TD - what difference does a larger compressor wheel make?
DD
I don't want a sig.
