Author Topic: Optimum Position for EGT Probe On Manifold  (Read 7848 times)
October 01, 2008, 02:05:44 am
Gernster
  • 87
« on: October 01, 2008, 02:05:44 am »
Have bought myself an EGT guage (& Boost) whilst my head is off.
Looking for the best place to drill & tap on a 1.6 GTD (SB/RA) exhaust manifold. I know I need to get close to the Turbo, but can you get too close??i.e should I be fitting right next to the turbo joint ot after the bend as it goes down to the downpipe?
Reply #1October 01, 2008, 03:13:13 am
dillenger1
  • 777
« Reply #1 on: October 01, 2008, 03:13:13 am »
Nope,that will give false readings .It will be cooler there by hundreds of degrees.You need it in the the combined stream in the exhaust manifold,preturbo.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2October 01, 2008, 05:15:52 am
saurkraut
  • 904
« Reply #2 on: October 01, 2008, 05:15:52 am »
Put 'er here:
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3October 01, 2008, 07:39:55 am
arb
« Reply #3 on: October 01, 2008, 07:39:55 am »
I put mine at the junction of the 3 & 4 runners. My first attempt resulted in a cracked manifold - so I used the drill press after I welded my crack. Here's my post on that - towards the bottom.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=15633&postdays=0&postorder=asc&start=0
Reply #4October 01, 2008, 11:40:27 am
saurkraut
  • 904
« Reply #4 on: October 01, 2008, 11:40:27 am »
The standard transverse manifold can easily be drilled with an electric hand drill.
Cobalt bits go through it like a hot knife through butter.  Make sure to cool the bit with some oil, WD40 works great.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5October 01, 2008, 11:44:25 am
Gernster
  • 87
« Reply #5 on: October 01, 2008, 11:44:25 am »
thanks guys, good job I asked!
Reply #6October 01, 2008, 12:17:34 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: October 01, 2008, 12:17:34 pm »
I see arb used high temp sealant. Did anyone not use any sealant? just drill tap and thread it in?
Reply #7October 01, 2008, 12:45:30 pm
saurkraut
  • 904
« Reply #7 on: October 01, 2008, 12:45:30 pm »
The Spruce and VDO thermocouples (The spruce thermocouple is the fastest) have pipe thread adaptors.
Pipe thread is tapered.
No sealant required.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #8October 02, 2008, 04:08:46 pm
Jet A
  • 125
« Reply #8 on: October 02, 2008, 04:08:46 pm »
dont forget your antisieze....
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #9October 03, 2008, 06:21:59 am
Gernster
  • 87
« Reply #9 on: October 03, 2008, 06:21:59 am »
dont think I'll ever have cause to remove it mate ;)
Reply #10October 03, 2008, 03:22:22 pm
Jet A
  • 125
« Reply #10 on: October 03, 2008, 03:22:22 pm »
Dont think youll remove it huh?
Seems easier to put the antisieze on that it will be to get back on here and ask how to get it out without damaging it.... :D
Reply #11October 16, 2008, 09:10:07 pm
79rabbit4dr
« Reply #11 on: October 16, 2008, 09:10:07 pm »
What about on a non-turbo'd rig? should it still be on the manifold, or can it be down on the pipe within the first foot or so of the block? Just wondering because I don't have a welder to fix my manifold if it cracks when tapping it for the probe. Picture for reference?
Reply #12October 17, 2008, 07:30:30 am
« Reply #12 on: October 17, 2008, 07:30:30 am »
Put it in the manifold.
I've never seen one crack due to drilling/ tapping.
The sender needs to be as close to the head as possible and in the combined exhaust stream.
Reply #13October 17, 2008, 02:25:59 pm
« Reply #13 on: October 17, 2008, 02:25:59 pm »
Why do you say that? If your running 1000 Degrees F in one cylinder, measuring two cylinders simultaneously won't show 2000 degrees. :P
Or is the probe in more exhaust so that makes it more accurate?
Seems to me if you put it too far from the head just to get all four cylinders it would read cooler because of the extra distance from the head.
Reply #14October 17, 2008, 02:38:04 pm
« Reply #14 on: October 17, 2008, 02:38:04 pm »
Quote from: "rabbitman"
Correct it wont read 2000 deg, if you only stick it in the stream of one or 2 ports you wont know what the others are doing. If you have 3 cyl running 600 and one running 1200deg it will show up on your EGT as a higher reading than the 600 deg thus the "Combined stream" application.
You are looking for a average here.
I said in the combined stream as close to the head as you can get so the average you are reading is more accurate, yes the farther from the head the colder it will read.
