Author Topic: Optimum Position for EGT Probe On Manifold  (Read 7893 times)
Reply #15October 17, 2008, 06:17:02 pm
« Reply #15 on: October 17, 2008, 06:17:02 pm »
If you have 3 cyl running 600 and one running 1200deg it will show up on your EGT as a higher reading than the 600 deg thus the "Combined stream" application.
Good point, so if you got one injector with a bad spray pattern or whatever it "should" show up, then you'd have to guess at which one it is.  I'll keep that in mind for when I drill the mani for my vnt-15.
Probably drilling 6inches from the head were they all meet won't affect the reading too much anyhow as the exhaust gasses are moving perdy fast.
Reply #16October 18, 2008, 05:49:26 pm
79rabbit4dr
« Reply #16 on: October 18, 2008, 05:49:26 pm »
And tapping one for each cyl would probably be overkill, esp on my stock '81 1.6 NA. and by the time i get to upping the power it'd be better to upgrade to custom/ceramic coated headers anyway, right?
Reply #17October 20, 2008, 09:16:10 am
Jet A
  • 125
« Reply #17 on: October 20, 2008, 09:16:10 am »
Quote from: "rabbitman"
One bad injector WILL show up as a hole in the piston..... :shock: not on the egt gauge. Especially if you push your egts!
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #18October 20, 2008, 09:54:29 am
« Reply #18 on: October 20, 2008, 09:54:29 am »
Quote from: "Jet A"
It WILL show up on the gauge LONG before there is a hole in the piston.
Providing you are starting out with a healthy engine you will have a baseline, using that baseline you will know if there is a problem. Your EGT's will go up even with one bad injector.
Reply #19October 21, 2008, 07:11:47 pm
« Reply #19 on: October 21, 2008, 07:11:47 pm »
The sender needs to be as close to the head as possible and in the combined exhaust stream.
Why do you say that? Seems to me if you put it too far from the head just to get all four cylinders it would read cooler because of the extra distance from the head.
Yup.. your exactly right.. :D
Reply #20October 21, 2008, 09:44:55 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
on this topic - but a bit of a hi-jack
« Reply #20 on: October 21, 2008, 09:44:55 pm »
ok, apart from diagnosing a bad injector, lets say you have an egt guage to keep a general idea on how your current "tune" is affecting things.
i'm still using the stock k14 turbo on my aaz with stock manifold, which is the 3 bolt type with flange on the end just outside number 4 cylinder for EGR stuff.
now, i will be sticking my egt probe in the junction when i change to t3 and a 4 bolt mani soon, but for now its mounted in a blanking plate where the egr used to be. i see good response on the guage (within the same gear) and so far max EGT i've seen has been 520C (970F) (20psi, accelerating at WOT 4th gear up hill to 70mph).
i figured that since (when it counts) the pressure inside the exhaust manifold must be around 30psi and large flow rate, that the probe, wherever its placed, should give a reasonably good reading, even though its only behind 1 exhaust port.
thoughts?
'91 Golf Cabrio 1.9TD
Reply #21October 29, 2008, 03:47:50 pm
Jettagli16v
  • 344
« Reply #21 on: October 29, 2008, 03:47:50 pm »
This manafold (pictured)
seems to be different than mine.
I have Garrett T3 (OEM)
and I dont think I have a boss where that one was placed.
Can I use the boss for the heat shield mount (Just a little closer to the turbo flange than the one pictured)?
I am installing a spruce thermocouple (Thanks, GTD!)
Reply #22October 29, 2008, 10:33:36 pm
79rabbit4dr
« Reply #22 on: October 29, 2008, 10:33:36 pm »
Where is a good place to get these and what brand should I go for?
Reply #23October 29, 2008, 10:50:17 pm
cyrus #1
  • 360
« Reply #23 on: October 29, 2008, 10:50:17 pm »
People seem to like the aircraft spruce thermocouple.  It reacts quickly and is reasonably inexpensive.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #24October 30, 2008, 05:27:21 am
saurkraut
  • 904
« Reply #24 on: October 30, 2008, 05:27:21 am »
Here's the Aircraftspruce superfast probe:
Link: Aircraftspruce
And here is a VDO EGT gauge:
Link: VDO Vision EGT Gauge
You'll need the lead wire, so you can either buy the gauge with the super slow VDO probe and use the supplied lead wire.
Or contact Libbybapa and see if he is still selling bulk thermocouple lead wire.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #25October 30, 2008, 07:05:05 pm
« Reply #25 on: October 30, 2008, 07:05:05 pm »
I have that setup and it works great!
Reply #26November 03, 2008, 03:04:24 pm
monomer
  • 414
« Reply #26 on: November 03, 2008, 03:04:24 pm »
I have the AS probe and gauge just waiting to be mounted and used...
www.michiganvw.org
Reply #27November 05, 2008, 12:42:11 am
  • 3468
    • McScrubbins Body Wash
« Reply #27 on: November 05, 2008, 12:42:11 am »
I ordered prothe's egt gauge and sender. Anyone use this one?
http://www.dieselvw.com/EGTGauge.htm
I think it's hilarious that it goes to 2,400 and then says "warning" after that.
Reply #28November 05, 2008, 07:50:26 am
« Reply #28 on: November 05, 2008, 07:50:26 am »
Well it says "Type R" so it must be good..
