Author Topic: Is my pump worn?  (Read 2939 times)
November 03, 2008, 03:59:02 am
molgrips
  • 134
Is my pump worn?
« on: November 03, 2008, 03:59:02 am »
I just re-checked my timing, was going to experiment, and I noticed that each time I set it, I re-checked it and got different results by about 0.3mm
Does that mean something's worn and sloppy in there or what?  Or is that normal?
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #1November 03, 2008, 04:30:19 pm
Mark(The Miser)UK
  • 1557
Re: Is my pump worn?
« Reply #1 on: November 03, 2008, 04:30:19 pm »
Quote from: "molgrips"
Simple test; do your timing measurement from the usual clockwise rotation, then rotate crank 720 degrees remeasure. Then compare with 360 degree rotation, finally  rotate anti clockwise repeating experiment. All clockwise readings should be the same, and all anticlockwise equal also.
Mark-The-Miser-UK
Reply #2November 04, 2008, 01:50:18 am
molgrips
  • 134
Is my pump worn?
« Reply #2 on: November 04, 2008, 01:50:18 am »
Thanks for the tip - I will do that next time.. but what if the readings are not the same?  Would this just mean my measuring tools are not very good, or could it be a pump fault?
Reply #3November 04, 2008, 03:49:16 pm
Mark(The Miser)UK
  • 1557
Is my pump worn?
« Reply #3 on: November 04, 2008, 03:49:16 pm »
I dunno either  :wink:
How about the pump's  cam lobes uneven. Surely they wear :?:
...Chicle or some other crud under a section of timing belt :lol:
Mark-The-Miser-UK
Reply #4November 04, 2008, 05:20:26 pm
Is my pump worn?
« Reply #4 on: November 04, 2008, 05:20:26 pm »
I find that if the adapter is not threaded in really tight or if the dial indicator is not attached to the adapter super tight the numbers can drift a bit.
And of course there's the most common problem... the adapter extension sticking a little bit.
I tend to "help" the spring in the dial indicator by pressing down on the upper stem of the dial indicator... often that's all it takes to click into place.
Reply #5November 04, 2008, 05:40:53 pm
Mark(The Miser)UK
  • 1557
Is my pump worn?
« Reply #5 on: November 04, 2008, 05:40:53 pm »
I agree with Vince....
And  Andrew :wink:
Heck, I even agree with myself a little :roll:
Mark-The-Miser-UK
Reply #6November 05, 2008, 02:44:24 am
molgrips
  • 134
Is my pump worn?
« Reply #6 on: November 05, 2008, 02:44:24 am »
Having had a little play with the dial and adapter, I think Vince is on the right track. At least I hope he is, who knows what my pump is like inside especially after all the various different fuels that've been through it :)
