Author Topic: R&R'ing same IP - does timing need to be set?  (Read 1982 times)
October 28, 2008, 06:51:21 pm
Mardak
  • 30
« on: October 28, 2008, 06:51:21 pm »
Hi guys,
I need to remove the injection pump on my brother's 90 Golf in order to remove the a/c, alt bracket (busted bolt inside the bracket).  I don't have much experience working on diesels (but almost 20 years experience on A1/A2 VW's) and was wondering if it's possible to remove/move the IP out of the way and bolt it back up without having to set the pump timing.   I just need to move it enough to gain access to the bracket bolt(s?) underneath.
Thanks for any advice!
Later,
Mark.
75 Scirocco
82 Scirocco
82 Rabbit Pickup - mTDI project
90 Audi Coupe Quattro 20v
90 Audi Coupe Quattro 10v turbo
Reply #1October 28, 2008, 07:01:46 pm
« Reply #1 on: October 28, 2008, 07:01:46 pm »
definitly needs to be retimed. If you are just rotating the pump, you could probably get away with just marking the pumps location relative to the bracket. I'd use 2 lines just to be safe
