Author Topic: Adjustable Cam Gear on a 1.6L TD or D?  (Read 4779 times)
October 06, 2008, 02:37:17 pm
VW_Commuter
  • 355
« on: October 06, 2008, 02:37:17 pm »
Anyone ever tried it?  Seems like it would make timing much easier.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #1October 06, 2008, 03:40:11 pm
« Reply #1 on: October 06, 2008, 03:40:11 pm »
It would have to be for a 16v right? I've thought about it, because I want to play around with cam timing a bit
Reply #2October 06, 2008, 04:04:21 pm
gigaz2
  • 626
« Reply #2 on: October 06, 2008, 04:04:21 pm »
you can play with timing with the stock setup, its tricky, but not impossible like with the gasser (keyed)
I would love to find an adjustable gasser sprocket with the correct diesel belt width (1.1" sprocket for the 1" belt)
Reply #3October 06, 2008, 04:13:18 pm
VW_Commuter
  • 355
« Reply #3 on: October 06, 2008, 04:13:18 pm »
What's the belt width for the 8v & 16V motors?
I was thinking about this because it would give you the security of the key and the ability to set our timing a little easier like the gasser guys.  I've seen some pretty nice adjustable cam gears for sale over on the vortex and just started to kick the idea around in my head.
Greg
Reply #4October 06, 2008, 04:59:15 pm
gigaz2
  • 626
« Reply #4 on: October 06, 2008, 04:59:15 pm »
one could turn a stock diesel one to adjustable, using the key as added security.
Reply #5October 06, 2008, 06:31:16 pm
« Reply #5 on: October 06, 2008, 06:31:16 pm »
I know for sure a 8v is too narrow. I'll measure up a 16V one when I get a chance
Reply #6October 06, 2008, 07:52:15 pm
VW_Commuter
  • 355
« Reply #6 on: October 06, 2008, 07:52:15 pm »
Thanks Tyler, I appreciate that.
Greg
Reply #7October 10, 2008, 10:06:46 pm
VW_Commuter
  • 355
« Reply #7 on: October 10, 2008, 10:06:46 pm »
Tyler, you ever get a chance to measure the width of the 16V adjustable cam gear?
Greg
Reply #8October 11, 2008, 05:49:40 am
« Reply #8 on: October 11, 2008, 05:49:40 am »
No not yet. Perhaps some time this week
Reply #9October 11, 2008, 06:52:57 am
« Reply #9 on: October 11, 2008, 06:52:57 am »
would be interesting to know of any gains...  i know on gassers you can suffer on low end but gain on top end with this.  for a diesel i wonder if you can gain low end but lose top end, which our stock motors don't have much of to begin with...
Reply #10October 11, 2008, 07:17:40 am
foxracer1
  • 991
« Reply #10 on: October 11, 2008, 07:17:40 am »
The 16v cam gear will not work. The cogs on the belt don't mesh properly. Already tried it. I'm in the process of cutting the tapered end off of a junk diesel cam. I plan to machine out the inside to a press fit tolerance and run a gasser cam. During all this i plan to make it adjustable.
When doing the timing belt on our 84 rabbit i tried moving the cam a little. I advanced it and it was not happy with that. It made lots of intake noise but didn't have power. So i retarded it and that is how it is. Nothing major noticed good or bad.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #11October 11, 2008, 09:11:15 am
VW_Commuter
  • 355
« Reply #11 on: October 11, 2008, 09:11:15 am »
Hmmm, I really wasn't looking to change the timing but just to make it easier to get it timed right on and also prevent the possibility of the cam gear from slipping on the cam itself.
Greg
Reply #12October 13, 2008, 12:02:22 pm
« Reply #12 on: October 13, 2008, 12:02:22 pm »
I guess I won't measure the belt thickness then. Thanks :)
Reply #13October 23, 2008, 11:00:52 pm
blkboostedtruck
  • 1535
« Reply #13 on: October 23, 2008, 11:00:52 pm »
i've never had one slip but i have busted the end of the cam off clean break!
in my early days of doing my own timing belt! well i learned to never use my ironworker 4lbs beater (hammer) beater is a trade name for them! and it was just a little tap too! :shock:  :oops:  :?  :(  :cry:  idiot !!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #14October 23, 2008, 11:51:57 pm
« Reply #14 on: October 23, 2008, 11:51:57 pm »
Me too :oops:  :roll: last winter, the stupid part was it was about my fifth time popping the gear off. :x $50 bucks for a reground one, and a week of down time. My problem was that I only loosened the bolt about half a turn, after it busted I needed a wrench to get the bolt all the way off so it must have tightened itself again......
