Author Topic: Still need a one hole head gasket  (Read 2665 times)
May 28, 2013, 07:10:12 pm
Gizmoman
  • 1301
« on: May 28, 2013, 07:10:12 pm »
I received my two head gaskets from Canada via UPS today - perfect timing!
Man was I bummed when I opened the package and discovered they are three hole gaskets!
Part number Victor Reinz 61-31225-30
Back on the hunt :(
Reply #1May 28, 2013, 07:24:33 pm
Gizmoman
  • 1301
Re: Still need a one hole head gasket
« Reply #1 on: May 28, 2013, 07:24:33 pm »
OK - all is well.
The three holes you see are not punched all the way through - only one is.
The new gasket is 2.12 mm
The one I had already installed and torqued several times (which only has one hole) measures 1.94 mm.
My guess is that the two I received will mash to the same thickness.
YAYYYYYYYYYYYYYY!
Big thanks to the very helpful dude to the North for really going the extra mile.
Reply #2May 28, 2013, 07:33:20 pm
« Reply #2 on: May 28, 2013, 07:33:20 pm »
UPS or USPS?
Reply #3May 28, 2013, 08:17:29 pm
Gizmoman
  • 1301
« Reply #3 on: May 28, 2013, 08:17:29 pm »
USPS (Santa)
Reply #4May 29, 2013, 05:20:15 am
« Reply #4 on: May 29, 2013, 05:20:15 am »
USPS (Santa)
That makes more sense. I try to avoid UPS for international stuff.
Looking forward to seeing some videos
Reply #5May 29, 2013, 06:05:36 am
« Reply #5 on: May 29, 2013, 06:05:36 am »
hey giz... what you doing with the old one? i need 1 to play with... a used one would be great.. else i guess who i need to hit up for a new one.. but hell i do not even know if this engine idea will work.. so a cheap used one would be perfect..
Reply #6May 29, 2013, 06:12:22 am
Gizmoman
  • 1301
« Reply #6 on: May 29, 2013, 06:12:22 am »
A pm and an address will get it to ya.
Frankly, I think its quite usable - just didn't want to chance it. BTW, I had it torqued to 125 ft/lbs per ARP spec.
Reply #7May 30, 2013, 02:52:26 am
« Reply #7 on: May 30, 2013, 02:52:26 am »
 :D  im doing something w/11mm studs... beleive me your holding a no idea if will work/not item i need for "test fit" at min and being 1 notch makes it perfect... pm on its way..
Reply #8May 30, 2013, 05:06:18 am
« Reply #8 on: May 30, 2013, 05:06:18 am »
I have the old HG from my 1.6 that was the 1 notch metal. Let me know if you need it for a template, as it was used.
