Author Topic: Cleaning valve pockets  (Read 5825 times)
February 14, 2010, 08:04:35 am
somolovitch3
  • 290
« on: February 14, 2010, 08:04:35 am »
Okay, having read all four pages from search, HOW does one clean the area under/above the valves in the 1.6 head?
I steam cleaned the head after taking it apart, there is still crud in this area. Use a copper/brass cup wheel on a drill (1-1/4 inch size or smaller)? Some kind of sandpaper flapper thing? Or maybe a chemical cleaning agent?
Any and all info/help is apprectiated.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #1February 14, 2010, 09:35:47 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: Cleaning valve pockets
« Reply #1 on: February 14, 2010, 09:35:47 am »
I dissassembled the head and used a MEDIA, not sand, MEDIA blaster to remove all of the carbon and crap.  the media is a specially designed round pellet/bead that doesn't take but surface dust etc, off of the surface that you want it to.  Worked wonders, see the pics in my build thread if ya don't believe me.
kevin
Reply #2February 14, 2010, 09:36:06 am
GEE-BEE
  • 1604
« Reply #2 on: February 14, 2010, 09:36:06 am »
HOT TANK ,
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3February 14, 2010, 11:18:05 am
somolovitch3
  • 290
« Reply #3 on: February 14, 2010, 11:18:05 am »
So were should one look to find media for blastin? I have a "blasting" unit.
Tank of hots costs $.  :P
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #4February 14, 2010, 11:28:22 am
NintendoKD
  • 931
    • myspace page
« Reply #4 on: February 14, 2010, 11:28:22 am »
Depending on the shop that does it, acid tanking shouldn't cost a fortune.  You can buy media/bead, not sand, at hardware stores.  I have three 100lb bags of sand for blasting but that isn't the right stuff, remember to wear breathing pro. don't want to wind up with silicosis.  They usually are sold in grades mine was a med grade, however ask the guys in the store and I'm sure that they can help you better select the product for you.
Kevin
Reply #5February 14, 2010, 12:58:04 pm
somolovitch3
  • 290
« Reply #5 on: February 14, 2010, 12:58:04 pm »
The really sucky part is that I work 7:30 am to 6:00 pm  (okay, that is the time away from home) and trying to get things to and then picked up from shop gets..................
I still have to get my mounts (with the new rubber {sortof} new, not rubber) back from that shop. Mon - Fri 8am to 4pm.
So ask at local hardware stores for ... will glass beading work? I know I can get that on the week end.
Thanks for all the help!
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #6February 14, 2010, 02:44:57 pm
VW Smokr
  • 114
« Reply #6 on: February 14, 2010, 02:44:57 pm »
Glass beading is somewhat easier on aluminum, due to the rounded particles, but it can still mess with sealing surfaces. Try oven cleaner & let it sit in there for a while. Once softened a bit, the carbonized crud may come flying outa there with Scotchbrite cookies on a die grinder or drill motor. Gloves n' goggles highly recommended!
As far as 'blasting' compounds, walnut shell media is supposed to do a good job without tearing up or even work-hardening the surface. These guys are not a great distance from you & do 'soda blasting'   http://www.stewartspecialtyservices.com/    They may have something for you.
Good luck on the project.
J.R.
SoCal
Reply #7February 14, 2010, 03:19:07 pm
somolovitch3
  • 290
« Reply #7 on: February 14, 2010, 03:19:07 pm »
Scotchbright cookies? ??? Avalable from the Girl Scouts? ::) Guessing 1" dia cutouts of the green pad?
Thanks for the help.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #8February 14, 2010, 04:25:10 pm
« Reply #8 on: February 14, 2010, 04:25:10 pm »
It is called rolocs. The maroon and blue are best for not harming the surface of aluminum. 2" are the most popular...I need to become a vendor and sell these to you guys:D
Reply #9February 14, 2010, 05:17:33 pm
NintendoKD
  • 931
    • myspace page
« Reply #9 on: February 14, 2010, 05:17:33 pm »
Yeah, those things are awesome, need a die grinder with the right nose though, when rebuilding i use the soft ones "blue" to clean contact surfaces.  Don't suggest these for inside the ports, I'm stickin with media, if you are smart, like I know you are, you will use a grinding compound and reseat your valves before you finish anyway to avoid sealing problems. ;)
Reply #10February 14, 2010, 06:17:27 pm
somolovitch3
  • 290
« Reply #10 on: February 14, 2010, 06:17:27 pm »
The forth and back on the valves is a given, just want to get the crud in the way of the in-ys and out-ys
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #11February 14, 2010, 06:39:48 pm
RadoTD
  • 513
    Stage WTF
« Reply #11 on: February 14, 2010, 06:39:48 pm »
I'd actually try to find a plastic blasting media. It doesn't create any heat, doesn't pit anything. I've used it stripping paint off of panels and it would take bondo off, but you could still see scratching from ~80grit on the metal before they painted it. Doesn't create any heat, so panel warpage is non existent.
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #12February 14, 2010, 07:27:52 pm
macka
  • 957
« Reply #12 on: February 14, 2010, 07:27:52 pm »
Hot tanking like GB said works and is cheap, media blasting is also good. I don't like using flap wheels or scotch brite pads. They can be too abrasive and damage the surfaces on those little innies and outties.
Quote from: Vincent Walden
Reply #13February 15, 2010, 07:46:05 am
« Reply #13 on: February 15, 2010, 07:46:05 am »
Whizzy wheels!... those things are the $#!T for cleaning aluminum.
Reply #14February 15, 2010, 12:24:33 pm
somolovitch3
  • 290
« Reply #14 on: February 15, 2010, 12:24:33 pm »
Is this a good thing? And I would need something in the 1" range. Will be trying the oven cleaner...today? maybe latter this week.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
