Author Topic: AGS trans vs ATH  (Read 3261 times)
March 17, 2010, 06:20:06 pm
bigblockchev
  • 271
AGS trans vs ATH
« on: March 17, 2010, 06:20:06 pm »
I have to drop in another trans into my MK3 AAZ, came with a ATH , first one blew a diff rivet & made 3 holes in the diff housing!! Bought another from a wrecker & it lasted 2 months then the shifter gizmo on top of the trans locked, up solid no in, no out, no back, no forth, weird!!! So I have a chance to pick up a AGS trans out of  a NA MK2 for reasonable money, ratios not perfect but about 10% higher rear end.  Nothing much around here for less than $400. So what is the deal with 90mm flanges or 100mm flanges. Can I swap these or what. Looking for a cheap solution for a broke student. Comments please?? Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #1March 17, 2010, 08:39:14 pm
Re: AGS trans vs ATH
« Reply #1 on: March 17, 2010, 08:39:14 pm »
flange swaps are very possible.
Reply #2March 20, 2010, 06:11:56 am
bvolks73
  • 183
« Reply #2 on: March 20, 2010, 06:11:56 am »
I just replaced the transmission in my 95 gasser Golf with one from a 92 Jetta and the only thing that was slightly different was the length of the "shifter gizmo". It already had the 100mm flanges but I had to take the passenger's one off to get it past the motor so changing the flanges isn't a problem. If the AGS has the big reverse light switch you might have to do some rewiring to make them work. I would have liked to found one out of a diesel to use but it blew on the weekend and I already had the AUG transmission all cleaned up in the basement.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #3March 20, 2010, 08:22:20 am
« Reply #3 on: March 20, 2010, 08:22:20 am »
you dont have to remove the flange to get it off the engine. i never have atleast. only time i take the drive flanges off is when they absolutely have to come off. they are kinda a *** to put back on when you have a trans with the springs and conical washers in it.
Reply #4March 20, 2010, 01:25:19 pm
bvolks73
  • 183
« Reply #4 on: March 20, 2010, 01:25:19 pm »
I've never had to take the flange off on the MKII cars but I tried for hours and couldn't get it to go in with the flange on. Maybe it was because I was putting it in alone lying on ice in the snow that I was having a hard time. It was definitely a pain getting the flange back on once it was in the car too.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #5March 20, 2010, 04:23:01 pm
« Reply #5 on: March 20, 2010, 04:23:01 pm »
i always pull the engine to do trans work. i hate trying to muscle a trans up into a car. because when the engine is hanging right in front of me, i can just pick the tranny right off and walk away. installation is just as simple.
Reply #6March 20, 2010, 06:39:38 pm
Dakotakid
  • 1240
« Reply #6 on: March 20, 2010, 06:39:38 pm »
#1 There are flange compressing tools sold for the job of getting th circlip off the output shaft. I think mine was made by AST tools.
#2 Next time, instead of removal of the flange...unbolt the trans and rotate it before removal.
Reply #7March 21, 2010, 04:51:08 am
bvolks73
  • 183
« Reply #7 on: March 21, 2010, 04:51:08 am »
That's how I've always done it but it would hit something on the backside that would keep it from rotating back up in place. I plan on replacing it with a transmission from a Diesel for better gearing so hopefully I'll have better luck next time.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #8March 22, 2010, 05:49:53 am
« Reply #8 on: March 22, 2010, 05:49:53 am »
that AGS you were looking at would have been every bit as good as a real diesel trans. for alot less money usually.
Reply #9March 22, 2010, 11:12:31 pm
  • 2932
« Reply #9 on: March 22, 2010, 11:12:31 pm »
AGS is a diesel trany.
 I got 2 TDs with them and have seen them in other MK2 diesels.
Reply #10March 23, 2010, 07:29:29 am
« Reply #10 on: March 23, 2010, 07:29:29 am »
ah, sorry. wasnt for sure. for some reason i thought the AGS and ACN came in econo box jettas and golfs.
Reply #11March 23, 2010, 11:24:08 pm
  • 2932
« Reply #11 on: March 23, 2010, 11:24:08 pm »
Yeah, I love the AGS,.. would be better with a .71...
Reply #12March 24, 2010, 03:30:17 pm
wolf_walker
  • 1205
« Reply #12 on: March 24, 2010, 03:30:17 pm »
I think that's what I put in my pickup, out of an early A2 Jetta D.  5th isn't tall enough, until there is a hill anyway.
I had a 7A that was awesome with a turbo diesel.
Mentat Text Two
Reply #13March 25, 2010, 07:46:59 am
« Reply #13 on: March 25, 2010, 07:46:59 am »
i like my ACN very well, i like that the first 4 gears are close, but not as close as a AUG or 9A or something like that. 4th in my ACN is like 5th in my AUG. the jump from 4th to fifht is big, but not as huge as a close ratio with a tall fifth.
