Author Topic: reasons for and against using a 1.9head with the 1.6 bottom?  (Read 2399 times)
March 11, 2010, 02:21:33 pm
the4ork
  • 331
« on: March 11, 2010, 02:21:33 pm »
just wondering, seems to me the major thing is they are newer and easier to find in good shape.
but in terms of performance, are we looking at any gains? i found a nice rebuilt shortblock, just wondering what i should do for a head
Reply #1March 11, 2010, 02:29:01 pm
Re: reasons for and against using a 1.9head with the 1.6 bottom?
« Reply #1 on: March 11, 2010, 02:29:01 pm »
lowers compression and way way way better intake ports.  and some have 7mm valve stems
Reply #2March 11, 2010, 02:59:39 pm
« Reply #2 on: March 11, 2010, 02:59:39 pm »
Lower compression may make for harder winter starts, but will be more efficient.  If you use the 1.9 head you need to get a 1.9 or TDI intake manifold as the port shape is different than the 1.6.
Reply #3March 11, 2010, 07:18:56 pm
« Reply #3 on: March 11, 2010, 07:18:56 pm »
I don't think you need to, but it would definitely be a good idea. Especially if you are running more then stock boost.
Reply #4March 11, 2010, 07:39:46 pm
« Reply #4 on: March 11, 2010, 07:39:46 pm »
Yup it's a performance thing, it would be useless if running NA and would be harder to start to boot.
Running TD you'll get more power with less boost, compared to a 1.6 head.
Reply #5March 12, 2010, 12:36:46 am
the4ork
  • 331
« Reply #5 on: March 12, 2010, 12:36:46 am »
cool, i plan on having a custom intake manifold made, and some porting and polishing. so this is good info.
Reply #6March 13, 2010, 09:37:11 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #6 on: March 13, 2010, 09:37:11 am »
there are already a couple o guys on here who have done it and are currently doing it "talking about myself"  I have hit a financial blockade currently and can't continue for a while, but you can be sure that I will finish.  I wish you the best of luck on this, most illustious of builds.
stay excellent 8),
bill, and ted "LOL, not really" Kevin
