Author Topic: serpentine on the 1.6  (Read 2568 times)
March 16, 2010, 04:29:41 pm
the4ork
  • 331
« on: March 16, 2010, 04:29:41 pm »
whats the parts list? aaz bracket, waterpump pulley, crank pulley and alternator?
i gotta buy all new ones anyways as ive lost all mine, might as well go serp, easier to change, belt lasts longer, makes less noise ect
Reply #1March 17, 2010, 01:05:06 am
the4ork
  • 331
Re: serpentine on the 1.6
« Reply #1 on: March 17, 2010, 01:05:06 am »
cool just read through that. sounds pretty easy.
one thing i need to figure out is how to get an a/c compressor fitted and working.
i can use the aaz compressor, but then what do i do about the compressor lines, as they are way different than the mk1 lines. i suppose i could use the aaz lines, but i would need an aaz condenser and evaporator, and im not sure if either will fit?  ???
Reply #2March 17, 2010, 07:38:19 am
« Reply #2 on: March 17, 2010, 07:38:19 am »
why dont you just use mk3 lines? disconnect the mk2 lines at the firewall and replace.
Reply #3March 17, 2010, 02:04:43 pm
the4ork
  • 331
« Reply #3 on: March 17, 2010, 02:04:43 pm »
because i have a mk1  8)
Reply #4March 19, 2010, 07:45:29 am
tindias
  • 56
« Reply #4 on: March 19, 2010, 07:45:29 am »
Would a G60 crank pulley fit a 1.6?  My current pulley has a wobble and need to replace it.  There are some G60 double pulleys that might line up with my charger better.
« Last Edit: March 19, 2010, 07:54:55 am by tindias »
'87 16v Scirocco w/ direct port nitrous
'81 Supercharged 1.6 Diesel Caddie
http://www.youtube.com/watch?v=XSAcDXLiCCk
'01 TDI Golf (daily driver)
Reply #5March 19, 2010, 05:14:21 pm
« Reply #5 on: March 19, 2010, 05:14:21 pm »
If you get the hose ends that fit the compressor, then you can get the hoses made up at almost anywhere that makes custom hoses.
Serious? All I need is a hydraulic hose shop and they can do it? I have that no problem I just thought it was something different. SWEET!
