Author Topic: 1.9td turbo swap  (Read 5257 times)
May 05, 2007, 11:39:16 am
fil1973
  • 6
1.9td turbo swap
« on: May 05, 2007, 11:39:16 am »
been told a turbo from a 1.6td would be a better turbo to replace my 1.9td one with, they said it is a bigger turbo with it being fitted to the smaller engine, is this so?
if not.  any ideas to make my standard 1.9td a little bit more responsive?
 any ideas greatly appriciated :?
Reply #1May 05, 2007, 12:28:43 pm
1.9td turbo swap
« Reply #1 on: May 05, 2007, 12:28:43 pm »
so they said that putting a turbo from a 1.6 onto a 1.9 is a smaller engine?  :?
Reply #2May 05, 2007, 04:46:50 pm
rubadubdub
  • 109
1.9td turbo swap
« Reply #2 on: May 05, 2007, 04:46:50 pm »
think what he was getting at was the turbo's bigger to make up for the fact its a smaller 1.6 engine. Correct me if im wrong.
1991 Mk2 Golf GTD
Reply #3May 07, 2007, 03:55:25 am
stewardc
1.9td turbo swap
« Reply #3 on: May 07, 2007, 03:55:25 am »
I'm putting a 1.6 turbo (Garrett T-3) on my new 1.9 AAZ to replace the stock KKK turbo. It will give more boost/power, though there will be more lag with the larger turbo.
  The small turbo on the 1.9 seems to be an emission cleanup item while the turbo on the 1.6 was meant for power only.
Reply #4May 07, 2007, 04:56:34 am
1.9td turbo swap
« Reply #4 on: May 07, 2007, 04:56:34 am »
well all you need is some proper fueling mods to get the turbo to spool up quicker... and with a nice bigger exhaust that shouldn't be a problem :)
i have a K24 on a 1.6 and it doesn't seem to take much to start boosting... with the fuel turned down to moderate levels it still doesn't take much at all to get it going...  so a T3 which spools better on a bigger 1.9 engine will be sweeeet!!!
Reply #5May 07, 2007, 05:47:10 am
stewardc
1.9td turbo swap
« Reply #5 on: May 07, 2007, 05:47:10 am »
I have also added a Giles pump and a 2.5" Passenger Performance downpipe, so I am expecting better spooling  8)
Reply #6May 07, 2007, 11:34:29 am
zaprzal
  • 160
    • turbodiesel.pl
1.9td turbo swap
« Reply #6 on: May 07, 2007, 11:34:29 am »
I swapped garrett t2 for k24 on 1.6td and I'm happy. It doesn't seem to be laggy, but I want to change it.... for something bigger   :lol:
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #7May 07, 2007, 12:35:38 pm
bert
  • 423
1.9td turbo swap
« Reply #7 on: May 07, 2007, 12:35:38 pm »
Ive gone with a T3 garrett as suggested by people off here and ITS AMAZING i took a few diesel geezers for a spin and the one s... his pants,he wanted to look under the bonnet he said no way 1.9 AAZ  :wink:  ive not touched the fuel screw,just the aneroid pin and used a 2.5" exhaust and set the pump to 1.0mm and WOW no intercooler either,and 11 psi boost
Anyone wants a go come and i will take you for a spin  :twisted:
Bert
Reply #8May 08, 2007, 12:06:05 pm
fil1973
  • 6
turboswap
« Reply #8 on: May 08, 2007, 12:06:05 pm »
thanx everyone for the help.... much appreciated
Reply #9May 08, 2007, 01:01:29 pm
addautomotive
1.9td turbo swap
« Reply #9 on: May 08, 2007, 01:01:29 pm »
Funny.
When my K03 bit the dust, I went with a T3. The difference in lag is really noticeable... especially around town.
The only time I'm really happy with the T3 is on the highway.
Reply #10May 08, 2007, 01:17:06 pm
stewardc
1.9td turbo swap
« Reply #10 on: May 08, 2007, 01:17:06 pm »
Quote from: addautomotive
Funny.
Get a bigger downpipe and exhaust and turn up the fuel screw a tad. You won't believe the difference.
Reply #11May 08, 2007, 02:02:22 pm
1.9td turbo swap
« Reply #11 on: May 08, 2007, 02:02:22 pm »
well a k03 would be pretty sweet for in town driving on a 1.6...  but higher egt's are a result :(
Reply #12May 09, 2007, 11:20:36 am
nogama3
  • 162
1.9td turbo swap
« Reply #12 on: May 09, 2007, 11:20:36 am »
Bert, your engine looks sweet and very clean. whats it running i terms of bhp?
i have a mk3 td that i took to derv doctor and is running 95 bhp.
Reply #13May 09, 2007, 11:55:37 am
bert
  • 423
1.9td turbo swap
« Reply #13 on: May 09, 2007, 11:55:37 am »
Nog,no idea what its running,how did you get 95HP out of yours,mines going on the dyno thing soon at hitech i know the owner and he said he will do a run and a printout  :wink:  what psi u running?
Bert
Reply #14May 09, 2007, 11:59:24 am
nogama3
  • 162
1.9td turbo swap
« Reply #14 on: May 09, 2007, 11:59:24 am »
when i bought it, the car was only running at 0.2 bar and i took it to the Gavin at the derv doctor who said he upped it to 1.2 bar. recent visit to stealth racing showed it was running at 0.8 bar so i need to take it down to have it adjusted. thinking of attaching an intercooler before i visit Gavin again, cost saving measure.
http://www.thedervdoctor.co.uk/
