Author Topic: Kolbenschmidt 1.6TD piston part #needed.  (Read 2411 times)
May 08, 2007, 12:23:15 pm
subsonic
  • 1836
« on: May 08, 2007, 12:23:15 pm »
Does someone know the part number for the Kolbenschmidt piston set
that is 1st overbore size?  I have the catalog, but do not see the actual
part number.  I need the number for the piston with the
 Dia. of  76.98mm,  and the Cyl Dia. of 77.01mm .
It should come with rings, piston pins , and clips.
In the 2007 catalog it is on Pg. 919,  Pos 24
Is the correct part number 90 732 610?
Thanks, jim
Found it.  Please see FAQ for part numbers
