Author Topic: timing and cr  (Read 8628 times)
October 03, 2011, 10:24:26 am
ibizz
  • 57
timing and cr
« on: October 03, 2011, 10:24:26 am »
hi again people
not first questions here about it , but since then the project stop becouse another priorities
now ive almost all stuff to turboed my 1y engine with vnt 15
the questions now is did anione that turboed same atmosferic engine bother changing timing and lower cr ?
« Last Edit: October 04, 2011, 04:06:24 am by ibizz »
Reply #1October 04, 2011, 12:10:50 pm
Re: timing and cr
« Reply #1 on: October 04, 2011, 12:10:50 pm »
my vnt15 build, i used the same compression and timing as a n/a.. worked fine.. my engine would benefit from more timing tho, i think..
Reply #2October 10, 2011, 03:31:03 am
ibizz
  • 57
Re: timing and cr
« Reply #2 on: October 10, 2011, 03:31:03 am »
thanks
same mecanic says that beter redard or advanced time , becouse of turbo but i dont know why ..
thats why im asking
how do you control your vnt geometry ?
i think il just change the vacuum acuateur for 1 pression wastegate .
Reply #3October 10, 2011, 03:43:20 am
ibizz
  • 57
Re: timing and cr
« Reply #3 on: October 10, 2011, 03:43:20 am »
did you calibrate the injectors ?
do you think its worth calibrate injectors for use with na pump ?
Reply #4October 10, 2011, 05:26:21 am
carrizog60
  • 978
Re: timing and cr
« Reply #4 on: October 10, 2011, 05:26:21 am »
use all specs like a TD engine.
timing near to 1mm, injectors at minimum 155bar.
search for some threads regarding vnt control,its well discussed here.
1Y is almost the same as aaz,so no worry for compression and such...
Portugal
Reply #5October 10, 2011, 07:03:18 am
gigaz2
  • 626
Re: timing and cr
« Reply #5 on: October 10, 2011, 07:03:18 am »
also, your mechanic is telling you the mods needed for gas engines, these are nothing like that ;)
Reply #6October 10, 2011, 09:33:05 am
Re: timing and cr
« Reply #6 on: October 10, 2011, 09:33:05 am »
130, or 135 bar injectors will both work just fine with an n/a or TD pump.. you just have to run a LITTLE more conservative timing on n/a injectors..
155bar injectors do atomize the fuel better, but either work just fine. ive never noticed a power difference with the different injectors ive run..
i have 135bar injectors, and a n/a fuel pump on my n/a long block. and it doesnt care at all. still makes very good power..
Reply #7October 11, 2011, 05:25:32 pm
ibizz
  • 57
Re: timing and cr
« Reply #7 on: October 11, 2011, 05:25:32 pm »
boas amigo
ja falamos
como esta a tua maquina ?
Reply #8October 11, 2011, 05:26:59 pm
ibizz
  • 57
Re: timing and cr
« Reply #8 on: October 11, 2011, 05:26:59 pm »
not my mecanic
just around corners mecanic LOL
Reply #9October 11, 2011, 05:32:02 pm
ibizz
  • 57
Re: timing and cr
« Reply #9 on: October 11, 2011, 05:32:02 pm »
from that you dont consider spend some money to calibrate them ?
n/a oem injectors ive 120 ? 130?
Reply #10October 12, 2011, 09:02:42 am
Re: timing and cr
« Reply #10 on: October 12, 2011, 09:02:42 am »
why would i calibrate injectors that were just built around 10k miles ago? the pump and injectors were already serviced on this car..
im not gonna re-calibrate if i were to want more break pressure.. i have a set of 155bar TD injectors, that were rebuilt around 15k miles ago..
why do you think you need to modify your injectors? stock injectors will work fine. may even make a little bit more power, because the injection pump doesnt have to build soo much pressure to open them..
i actually prefer to use the injectors that the pump is timed to. every time you change the brake pressure, you have to change the timing..
more break pressure = later timing, and you fix that by advancing it..
do what you want tho, if your MIND IS SET on paying someone to calibrate your injectors, then go for it. the only time i would suggest it, is if you are rebuilding your engine, or your injectors have a TON of miles on them, or are smokey at cold idle, or it has starting issues, or something like that.. if they are noisy, or a cylinder is missing, then its not a bad idea.
its generally not a good idea to have perfectly good injectors re-built. pop tested isnt a bad idea, plus you can check the spray pattern while your at it..
where are you getting 120bar and 130bar OEM injectors?!?!?!
only kind ive seen OEM are 130bar, and 135bar injectors in n/a engines.
155bar in TD engine
180bar in a 1.5D
Reply #11October 12, 2011, 04:39:29 pm
ibizz
  • 57
Re: timing and cr
« Reply #11 on: October 12, 2011, 04:39:29 pm »
thanks friend
this is what im trying to ask ..
sorry my rusty ingles ..
i im not set my mind to calibrate , in fact im asking becouse if its not very important i skip this step
the stuf to plug in cost god bucks in this portuguese crysis lol
so for now im tring to skip the minor things .
another question comes to mind , since the stuf is in my hands
its whorth make pot and polish in admission and exaust manifolds ?
Reply #12October 12, 2011, 04:45:11 pm
Re: timing and cr
« Reply #12 on: October 12, 2011, 04:45:11 pm »
thanks friend
how much power you looking to build? there wont be much, if any difference on an n/a engine..
you might notice it if you are going turbo charged, and your building up over 100hp.
if you feel like gasket matching the intake and exhaust ports, it wont hurt.. but with the stock TD, and n/a intakes, they both flow soo horribly, that porting doesnt even do much good.
i got more power when i changed over to a gasser CIS manifold from the TD manifold, rather than when i ported my head. if you can fit a gasser intake manifold, they make a good boost in low end power..
Reply #13October 12, 2011, 05:06:06 pm
ibizz
  • 57
Re: timing and cr
« Reply #13 on: October 12, 2011, 05:06:06 pm »
my engine is a 1y with that  huge admission manifold that is good for big turbos , not litle like vnt15
i dont know the gasser one ..
but what ive to trying to reach 100 , 110 hp is
vnt 15 , afn 110 exaust and admission manifolds
intercooler with original tubbing from afn too
and ive the exaust line 55mm from gttdi 110 too
so no n.a manifolds
Reply #14October 13, 2011, 07:41:22 am
Re: timing and cr
« Reply #14 on: October 13, 2011, 07:41:22 am »
sorry dude, its just a bit hard for me to follow your thread.. makes my head hurt to just read it. its too jumbled.
the bottom line tho, use the 1Y intake manifold, and the TD exhaust manifold/turbo..
you gotta get oil feed lines, and return lines made up, or bought tho. along with everything else for it.
you will get 100hp out of the n/a pump on the 1Y without much problem.
