Author Topic: timing and cr  (Read 8553 times)
Reply #15October 15, 2011, 05:13:51 pm
ibizz
  • 57
Re: timing and cr
« Reply #15 on: October 15, 2011, 05:13:51 pm »
 thanks
here people plug oil suply for turbo ?
what system do you ive for control vanes ?
Reply #16October 16, 2011, 12:44:27 am
Mark(The Miser)UK
  • 1557
Re: timing and cr
« Reply #16 on: October 16, 2011, 12:44:27 am »
where are you getting 120bar and 130bar OEM injectors?!?!?!
only kind ive seen OEM are 130bar, and 135bar injectors in n/a engines.
155bar in TD engine
180bar in a 1.5D
I think that 120 bar is the wear  limit.
ROR2.0 can you please find the source for the 180 bar vw 1.5D injectors?
The last time I checked the whole of the internet, the only location for those values was here on this forum :o. It is clearly a very essential value for yellow dot users.
Does anyone have any Rabbit brochures for promoting the benefits of purchasing the  car for that year?
Mark-The-Miser-UK
Reply #17October 16, 2011, 12:54:04 am
carrizog60
  • 978
Re: timing and cr
« Reply #17 on: October 16, 2011, 12:54:04 am »
use all specs like a TD engine.
timing near to 1mm, injectors at minimum 155bar.
search for some threads regarding vnt control,its well discussed here.
1Y is almost the same as aaz,so no worry for compression and such...
boas amigo
ja falamos
como esta a tua maquina ?
like this.
still going like day 1 and i am building a 11mm pump for it at the moment.
http://www.youtube.com/watch?v=FiQvU6AQRXE
hope this get you inspired to get your hands dirty and build that engine!
Portugal
Reply #18October 16, 2011, 09:09:37 am
Re: timing and cr
« Reply #18 on: October 16, 2011, 09:09:37 am »
boas amigo
ja falamos
like this.
wow.. your car is the sex...  8)
Reply #19October 16, 2011, 09:45:24 am
carrizog60
  • 978
Re: timing and cr
« Reply #19 on: October 16, 2011, 09:45:24 am »
thanks! 8)
Portugal
Reply #20October 16, 2011, 09:49:14 am
Re: timing and cr
« Reply #20 on: October 16, 2011, 09:49:14 am »
155bar in TD engine
180bar in a 1.5D
i agree with out a reliable source, information like that shouldn't be posted, like u i have never seen any other source for that number other than here.
Reply #21October 16, 2011, 10:20:06 am
Re: timing and cr
« Reply #21 on: October 16, 2011, 10:20:06 am »
why the he!! else would the 1.5 have a 1.15mm timing spec??
it has a super soft, very early advance also..
i swear that ive seen a set ov 180bar injector bodies before even.. that was years ago tho. didnt know how significant they were.. they may have been some other break pressure tho.. it was long ago, and i cant say for sure..
Reply #22October 16, 2011, 10:30:03 am
Re: timing and cr
« Reply #22 on: October 16, 2011, 10:30:03 am »
i don't know about the timing, that is where i have my yellow dot pump set at on my 81 rabbit with 135 bar injectors, and it runs properly, doesn't sound too advanced or anything at all(unless i pull the cold start). if u are not 100%  certain about something u should mention that when u are posting info about it.
Reply #23October 16, 2011, 10:35:08 am
Re: timing and cr
« Reply #23 on: October 16, 2011, 10:35:08 am »
well, if you are un-sure about info, and dont post about it, then you will never know if you are right or wrong.. make sense broseph?
i figured someone would confirm/deny the myth of 180bar squirters..
Reply #24October 16, 2011, 11:34:02 am
mtrans
  • 308
Re: timing and cr
« Reply #24 on: October 16, 2011, 11:34:02 am »
Nozzle opening pressure - new/used bar      125±5/112±5
Leak rate (dribble)   bar/seks       110/10
by AUTODATA for my Fiat 2500 NA.
I`ll improve my English
Reply #25October 17, 2011, 05:48:05 am
ibizz
  • 57
Re: timing and cr
« Reply #25 on: October 17, 2011, 05:48:05 am »
hey carrizog60
how do you control vanes ?
changing vacuum can by a waste gate ?
here you get oil supler to turbo , in oil sandwich ?
Reply #26October 17, 2011, 06:55:22 am
Mark(The Miser)UK
  • 1557
Re: timing and cr
« Reply #26 on: October 17, 2011, 06:55:22 am »
I'm partly in agreement with you, it would make sense, all other things being equal.
Why did VAG not go for an even softer spring and do away with the higher internal pump pressures if all they wanted was faster advance?
Greater atomisation does not improve efficiency IMO in a swirl chamber engine.
Most DN0 nozzles are run at 130bar ish for n/a's and 150ish for TD's  There are exceptions, and I'll dig them out that go down to 110bar and about 3 engines from other makers that use 175 to 190 bar. Not sure if they are swirl or not, but at 200bar we get into the DI world....
What if the cam plate was a different profile, could that account for the anomaly?
We need either brochures from that period, or OEM owners 8)
Was it even merely an attempt at emissions control, or an attempt to deal with fuel change, or performance related?
Mark-The-Miser-UK
Reply #27October 17, 2011, 08:32:57 am
92EcoDiesel Jetta
Re: timing and cr
« Reply #27 on: October 17, 2011, 08:32:57 am »
Can you explain why you think that? My thinking is that greater atomization is always a good thing, so smaller droplet + swirl would combust more than bigger droplets + swirl.
Reply #28October 17, 2011, 08:35:29 am
Re: timing and cr
« Reply #28 on: October 17, 2011, 08:35:29 am »
i do agree the advanced timing would make sense with the higher breaking pressure, but my car drives very smoothly and quietly at 1.15, if it were the regular pump that far advanced even with td injectors, i would think it would sound like a tin of marbles tumbling down the stairs.  a different cam profile is something i had though as well, i could measure total life on my car i suppose.
Reply #29October 17, 2011, 08:38:26 am
Re: timing and cr
« Reply #29 on: October 17, 2011, 08:38:26 am »
i think the idea is that a larger droplet will burn more slowly, so it would be more likely to burn in the combustion chamber, rather than in the precombustion chamber where a lot of heat energy is wasted, which is the real down fall of the idi engine.
