Author Topic: Don't buy Sealed Power Intake Valves for AAZ  (Read 2956 times)
August 05, 2011, 05:10:47 pm
erice1984
  • 263
« on: August 05, 2011, 05:10:47 pm »
I say again don't buy their intake valves.
Reason I say this, is because they stated on the RockAuto.com website their stem diameter is 7.925mm
I called Sealed Power to confirm this and they said that it is correct.
Bentley states new intake valve stem diameter of 7.970mm.
Bentley also states wear limit on said valves of 7.920mm.
.05mm is the equivalent to .002" rounded up (.0017")
1980 Rabbit 1.9TD
Reply #1August 06, 2011, 08:08:44 am
Re: Don't buy Sealed Power Intake Valves for AAZ
« Reply #1 on: August 06, 2011, 08:08:44 am »
John at air cooled engines plus will sell you all stainless valves for probably what you have in the rockauto ones.
Reply #2August 06, 2011, 08:28:38 am
erice1984
  • 263
« Reply #2 on: August 06, 2011, 08:28:38 am »
I only spent 6 bucks a valve for intake. I was just lookin out for others
1980 Rabbit 1.9TD
Reply #3August 06, 2011, 08:31:20 am
« Reply #3 on: August 06, 2011, 08:31:20 am »
Dang, I think I had 8 per valve intake and ex. If you still need them. I had around 60.00 in all 8v. The OEM sodium filled ex valve is almost that.
Reply #4August 06, 2011, 11:38:42 am
« Reply #4 on: August 06, 2011, 11:38:42 am »
I paid waaaay more than that from aircooled engines plus, I think it came out to almost $15 per valve.
Reply #5October 15, 2011, 12:41:45 pm
Alcaid
  • 549
« Reply #5 on: October 15, 2011, 12:41:45 pm »
Does Air Cooled Engines Plus supply oversize stainless AAZ valves as well? Does anyone know what kind of stainless material they use?
'10 VW Passat 1.6TDI Highline
