Author Topic: some pics of my mk1 project  (Read 5111 times)
September 11, 2011, 12:08:12 pm
bgbmxer
  • 107
« on: September 11, 2011, 12:08:12 pm »
Reply #1September 11, 2011, 12:09:07 pm
Re: some pics of my mk1 project
« Reply #1 on: September 11, 2011, 12:09:07 pm »
looks gay
Reply #2September 11, 2011, 12:17:47 pm
bgbmxer
  • 107
« Reply #2 on: September 11, 2011, 12:17:47 pm »
looks gay
coming over to check it out lol
Reply #3September 11, 2011, 01:07:01 pm
rallydiesel
  • 1880
« Reply #3 on: September 11, 2011, 01:07:01 pm »
I like it all except for the PVC tubing. What turbo are you running and do you smoke like mofo off boost?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4September 11, 2011, 02:13:44 pm
bgbmxer
  • 107
« Reply #4 on: September 11, 2011, 02:13:44 pm »
its a mitsubishi teo4h off of a 2.5 turbo dodge caravan. whats wrong with the pvc lol. and if im full throttle it will smoke a bit till it spools up but if im just cruzing around not bad at all
Reply #5September 11, 2011, 06:30:51 pm
punkvideo81
  • 168
« Reply #5 on: September 11, 2011, 06:30:51 pm »
Nice intake. Did you have to cut the radiator support to fit the intercooler? Can you post a shot of how it fits down there? I think pvc is recommended against. I'd like to see a video of it taking off from a deadstop & maybe a drive by if you can. Good luck with it!
'81 Caddy 1.6 TD
Reply #6September 11, 2011, 06:44:52 pm
bgbmxer
  • 107
« Reply #6 on: September 11, 2011, 06:44:52 pm »
ill take some pictures of the mounting of the intercooler. i actually cut the bumper and it sits out in front of the core support. the only cutting involved in the core support is the holes where the piping goes through.
pvc is fine if you use the right kind schedual 20 and 40 wont take the heat but schedual 80 will.
i can probably get a vid or two going but i cant beat on it to hard since the clutch just started slipping when i run it hard.
Reply #7September 11, 2011, 07:03:33 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #7 on: September 11, 2011, 07:03:33 pm »
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #8September 11, 2011, 08:50:21 pm
« Reply #8 on: September 11, 2011, 08:50:21 pm »
brandon stopped by after supper, the car runs really well, its unfortunate the clutch started slipping, cause the car really has balls and lots of potential, it's built really well, the only upgrade for it would be better turbo or an aaz head.  turbo spool is as good as the stock t3 and k24, egts are very very low.  on the compressor map the 1.6 doesn't go through the most efficient part of the map, but it stays on the healthier part of the teo4 map, definitely is a good turbo on the 1.6 and the compressor is good for 20-24psi.  it has a larger exhaust a/r than what is normally on a diesel but that doesn't seem to have effected spool up, but it does seem to be keeping egts low.
Reply #9September 12, 2011, 01:09:44 am
bgbmxer
  • 107
« Reply #9 on: September 12, 2011, 01:09:44 am »
since i have to replace the clutch while the trans is out i might have to change to the garrett turbo lol.
Reply #10September 12, 2011, 05:41:38 am
punkvideo81
  • 168
« Reply #10 on: September 12, 2011, 05:41:38 am »
...or a VNT 15 turbo
'81 Caddy 1.6 TD
Reply #11September 12, 2011, 07:45:40 am
« Reply #11 on: September 12, 2011, 07:45:40 am »
x3!!!
boost comes on soo low with a VNT..
i find my boost useable from ~2000 revs and up..
Reply #12September 12, 2011, 08:44:16 am
« Reply #12 on: September 12, 2011, 08:44:16 am »
nah u wanna go bigger not smaller  :P
Reply #13September 12, 2011, 08:45:27 am
« Reply #13 on: September 12, 2011, 08:45:27 am »
a VNT 15 will probably blow the socks off that TE04 in air flow and spool up..
not saying that just because i own one either..
Reply #14September 12, 2011, 03:19:10 pm
« Reply #14 on: September 12, 2011, 03:19:10 pm »
teo4 is capable of more flow and more pressure, i'm sure the vnt spools up much much more quickly tho.  i looked at the specs of the t3 from a turbo dodge, its specs match the 45 trim mercedes diesel t3, like powered by spearco has on his car except for that it has a water cooled center section, so it would work but he'll need good fueling to make it a viable turbo.
