Author Topic: im shaft pulley how u guys remove that with minimal tools?  (Read 2218 times)
September 17, 2011, 09:55:03 am
« on: September 17, 2011, 09:55:03 am »
so i don't have a pulley puller... shame on me.  and i'm having trouble getting the intermediate shaft pulley off, i've been trying to pry it from the holes on the inside, because i don't want to pry on the edge and bend or break off the lip on the im pulley.  any suggestions?  i feel dumb here, i know its not a press fit or anything, but this bugger is really on there
Reply #1September 17, 2011, 10:05:39 am
Re: im shaft pulley how u guys remove that with minimal tools?
« Reply #1 on: September 17, 2011, 10:05:39 am »
ive never needed anything more than my hand to remove them. maybe a little pry at the edge from a screw driver..
if you are CAREFUL.. you can get something in there, and pry from the bottom edge, and not touch the lip..
Reply #2September 17, 2011, 10:08:11 am
« Reply #2 on: September 17, 2011, 10:08:11 am »
what i been trying here now is i am prying from an inside hole, i put the bolt back in loosely, and i am tapping on the bolt trying to free the pulley, what the heck... i probably should have driven this car till it was hot before i started working.  i'll see if i can get a screw driver under in  a way won't effect the edge.
Reply #3September 17, 2011, 10:15:02 am
« Reply #3 on: September 17, 2011, 10:15:02 am »
if you got the car hot, it would be worse.. the IM shaft would be hotter (more expanded) than the aluminum..
it SHOULD wiggle right off the shaft.. its probably corroded on there i imagine..
hit it with PB blaster right at the shaft.. both sides if you can.
Reply #4September 17, 2011, 10:20:20 am
« Reply #4 on: September 17, 2011, 10:20:20 am »
yeah i doubt this pulley has ever been off the car in 30 years. none of my neighbors or mechanical either so i can't borrow tools and i can't go anywhere cause my cars torn apart haha.
Reply #5September 17, 2011, 11:11:38 am
« Reply #5 on: September 17, 2011, 11:11:38 am »
If you have a torch, even a little propane one you could blast the pulley. It'll out-expand the shaft and probably slip right off. Might need a new seal though.
fwiw mine have always slid right off. ;D
Reply #6September 17, 2011, 02:37:28 pm
« Reply #6 on: September 17, 2011, 02:37:28 pm »
well it needed a new seal anyway, i got it off, i had to use the local diesel nuts little pulley puller he made himself, since a regular one wouldnt fit.
