Author Topic: glove box light  (Read 4273 times)
September 17, 2011, 09:49:45 am
92EcoDiesel Jetta
glove box light
« on: September 17, 2011, 09:49:45 am »
Is it also actuated by the door opening/ closing? There is a switch on the light but it is still not getting voltage after replacing fuse #4.
Reply #1September 17, 2011, 10:07:04 am
Re: glove box light
« Reply #1 on: September 17, 2011, 10:07:04 am »
the one in my 85 GTI, was operated by the glove box opening.. no need for key power. you could drain the battery if you left the GB open..
the one in my 86 GTI, was operated by a small switch INSIDE the glove box, and it only works when the key is ON.
Reply #2September 17, 2011, 11:19:05 am
92EcoDiesel Jetta
Re: glove box light
« Reply #2 on: September 17, 2011, 11:19:05 am »
Eithe way, it's a stupis design! It should be tied to the same fuse as the door courtesy lights i.e no key required and should not require a maual switch.
Reply #3September 17, 2011, 11:00:45 pm
DieselBalz
  • 301
Re: glove box light
« Reply #3 on: September 17, 2011, 11:00:45 pm »
Make it that way.
Reply #4September 18, 2011, 05:21:08 am
92EcoDiesel Jetta
Re: glove box light
« Reply #4 on: September 18, 2011, 05:21:08 am »
What's the bulb number? Niether Pepboys nor Autozone show a listing for it.
Reply #5September 18, 2011, 12:29:42 pm
92EcoDiesel Jetta
Re: glove box light
« Reply #5 on: September 18, 2011, 12:29:42 pm »
Never mind the bulb number. Don't need it no more. I bent the contacts to fit a longer bulb, which I have plenty in spares and they more common and cheap.
Reply #6September 18, 2011, 12:33:12 pm
Re: glove box light
« Reply #6 on: September 18, 2011, 12:33:12 pm »
is it the right wattage? if you install a high wattage bulb in there, it may melt things..
Reply #7September 18, 2011, 12:37:12 pm
92EcoDiesel Jetta
Re: glove box light
« Reply #7 on: September 18, 2011, 12:37:12 pm »
I dunno. Do you know what wattage it should be? It's a bulb for courtesy lights in another car. I can measure the wattage of the bulb and report back.
Reply #8September 18, 2011, 01:00:31 pm
Re: glove box light
« Reply #8 on: September 18, 2011, 01:00:31 pm »
i think the stock GB light is 5w.. i guess i could go double check to make sure..
Reply #9September 19, 2011, 10:53:35 am
silentdub
  • 135
Re: glove box light
« Reply #9 on: September 19, 2011, 10:53:35 am »
Well, Are you really going to leave your glove box open long enough for *** to melt?  ???
